586,406 active members*
2,600 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Lathe thread cutting problem V26
Results 1 to 3 of 3
    Aug 2007
    24
    I have recently upgraded to V26 and I think there is a bug in the threading parameters menu.
    If you change the thread height from the default and compute everything is good.
    If you go back to edit the parameters the thread height has reverted back to the default, this ruined my thread as I had not seen this when I re computed the tool path.
    Please could someone have a look on their system to check if the problem can be repeated.
    The parameters I used were (metric) 2.5 pitch, 1.2 thread height, 0.1 first cut amount, 0.05 last cut amount, 0 deg thread in-feed angle.
    Thanks Bill.
    Jan 2011
    380
    Re: Lathe thread cutting problem V26
    Not sure about V26, but I know it does also happen on my V25
    Aug 2007
    24
    Perhaps Al could come in on this and explain where I am going wrong.
    I reported this as a bug and Autumn has replied to me stating that it is not a bug.
    This does not happen in V24
    Thanks in advance
  1. Thread cutting problem!
    By w0mbat in forum Benchtop Machines
    Last Post: 04-02-2012, 05:04 PM
  2. Thread cutting Ikegai lathe
    By hammer28 in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2010, 02:54 AM
  3. Thread cutting problem
    By wab0372 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-22-2008, 05:20 AM
  4. Cutting thread on CNC lathe by Mach3 ?
    By jimmychand in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2008, 06:12 PM
  5. Thread Cutting on MAXIMAT V10 Lathe
    By Kiwi in forum MetalWork Discussion
    Last Post: 06-18-2006, 06:32 PM
