I'm hogging out a 1.8" diameter, 2.5" deep hole in 6061-T6.
The mill is 2hp with a maximum torque of about 30 in/lbs and a max rpm of 7000.
Right now I can run a HSS, 1" dia, 2 flute, square centercutting end mill at around 3000 rpm to do it.
I have the toolpath spiral down at about 17ipm horizontal and 0.5ipm down.
I use air as coolant because my flood coolant system is low pressure and cant get down in there (the end mill just pumps it out).
The machine comes very close to stalling and sometimes does, the air coming out of the hole is, i'd say, hot.
I'd like to buy another end mill for this. I would think that the one I'm using is A) fairly dull..it was used when I got it B) probably not the absolute best choice for this cut.
I dont think there is an issue with the end mill I'm using chattering or any rigidity issues with the mill or setup. The issue is simply the power required for the cut.
Is there a better end mill geometry for this? I can pay up to $50 for something, used is okay (probably mandatory).
Its a cast iron mini mill, with a 10 x 7 x 10" envelope.
How about helix angle? Maybe 3 flutes would be better? Any particular brands that would be extra-sharp? What about the end-geometry (gash and all those funny angles).
Or how about a centercutting hog mill? Or maybe a bigger or smaller diameter?
Just trying to find the "sweet spot"..any help greatly appreciated!!
If I can cut power requirements by 25% that would be huge!
