586,596 active members*
3,221 visitors online*
Results 1 to 6 of 6
    Dec 2012
    569
    odd backlash goes backwards!
    I tried tightening up my 3 axis mill's Z axis backlash, because I was getting around .002" and I figured it could do better than that.
    I tightened the pulley/nut combo on the ballscrew.
    The backlash went down to about 0.0013"..but something odd is going on...
    I put my 0.0001" tenths indicator in the spindle and lowered it to the bed.
    Using the tenths 0.0001" jog, I tried to examine how the backlash behaves.
    What I noticed is, if I jog until the needle is regularly moving in one direction, then switch directions to go the other way (and measure backlash), the needle KEEPS GOING in the wrong direction for maybe 0.001"! Which is ten jog steps.
    I thought maybe it was the head tilting on the gibs as the force of the ballscrew changed direction, but its the wrong direction for that, it should be the other way shouldnt it?
    Is there some known reason why this would be happening?
    When I first start off reversing direction, I can see the DTI responding even in the first couple tenths..so it makes me think that I could get the backlash much lower since apparently there is coupling to the stepper motor that soon.
    Dec 2012
    569
    Re: odd backlash goes backwards!
    clarification:
    the first 10 jogs of 0.0001" (tenths) after reversing direction moves the head the wrong direction by about one tenth 0.0001"
    Feb 2009
    6028
    Control type?
    Dec 2012
    569
    Quote Originally Posted by underthetire View Post
    Control type?
    the motors are brushless servos with encoder feedback and motor controllers with analog control signal inputs..all going to a proprietary control system
    the reason I'm sure its not electrical is that I can see the ball screw turning in the correct direction during the whole thing
    Feb 2009
    6028
    Sounds like racking of the slide then.
    Dec 2012
    569
    What is that? Could you explain another way please.
  1. going backwards.
    By jestalavita in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2013, 09:15 AM
  2. Spiral anti-backlash couplers introducing backlash!
    By MArruda in forum DIY CNC Router Table Machines
    Last Post: 06-07-2011, 08:31 AM
  3. backwards G19
    By chippah in forum Vertical Mill, Lathe Project Log
    Last Post: 07-28-2010, 03:59 PM
  4. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  5. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
