586,403 active members*
2,619 visitors online*
    Jun 2008
    71
    Pictures for Bloke
    This one is of the whole card cage
    Attachment 245728
    Maybe this block between the boards?
    Attachment 245730
    Jun 2008
    1104
    Re: Pictures for Bloke
    The little block with Benchmarq is the BIOS battery module.
    Have a look here for clues...
    DALLAS / ODIN / BENCHMARQ Modul modifizieren ? BIOS Battery MOD
    I'm not sure if they are still available but if you get the number off the top, you may be able to source one.
    Jun 2008
    71
    Thanks for the information, I will look for one.
    Oct 2004
    188
    you can still get them. It is getting some one to turn them on for you that is the issue. The battery is turned off in the chip, needs to be turned on. Have to send it a sting via SPI to turn it on. If you are handy with a arduino or know some on that is that would be simple they give instructions in the data sheet.
    Oct 2004
    188
    I cannot figure how to edit my previous post But I may be wrong.
    I have a peak 570 out of a hurco on my bench that was booting up with CMOS battery Failure.
    Ordered a coupe of dallas DS12887+, that is a cross for the bechmark. Looking over the datasheet for the IC, tells you have to turn it on.
    Figured screw it plug it in and try. It works, at least I think it is. The battery failure alarm went away, and it keeps the bios settings. Will leave it off for the night and let you know in the morning.
    Turned it back on this morning, Time and date was correct and the CMOS parameters were all there. Tried a DS12887A in it this after noon and it worked as well.
    They are available from digikey.
  1. Paging Bloke - MD3 4th axis again!
    By gthlm in forum HURCO
    Last Post: 02-01-2011, 01:22 AM
  2. Bloke - MB3 battery backup?
    By underdog in forum HURCO
    Last Post: 10-05-2010, 12:40 AM
  3. New bloke on the block
    By IronBear in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 08:26 PM
  4. high all, new bloke to cnc zone
    By bernster in forum Australia, New Zealand Club House
    Last Post: 09-05-2009, 02:01 AM
  5. New Bloke from Brum
    By schneckster in forum European Club House
    Last Post: 06-11-2009, 10:18 PM
