Originally Posted by
TomKerekes
I thought you said you received an "GCode Error GCode Aborted". But now you say it hangs "Program not responding" ?
I would back up the system before re-loading software. I don't know if K2CNC Flashes anything to the KFLOP board. If you Flash New Version to KFLOP anything K2CNC Flashed to the board will be lost. We don't normally recommend anything to be Flashed to KFLOP.
What Version are you running? If it was working before and now not, then something must have changed.
What is the minimum you have to do to recover? Can you just restart KMotionCNC? Reinitialize KFLOP? Power Cycle KFLOP?
Please ask questions on the Forum.
Regards
