586,399 active members*
3,205 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam 2017 r2 Biesse Rover 24
Results 1 to 2 of 2
    Dec 2018
    1
    Exclamation
    Apr 2015
    327
    Re: Alphacam 2017 r2 Biesse Rover 24
    Firstly check if in add ins you have active all what you need. Then you can check also in a File -- Customise --- Customize Ribbon if your function missing in Ribbon.
    Problem can be also with your postprocessor 32bit VBA codes does not work on a 64bit Alphacam. It is necesary update it.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
