586,560 active members*
3,601 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Does anyone need service manuals for popular Doosan Machines?
Page 4 of 9 23456
Results 61 to 80 of 179
  1. #61
    Feb 2017
    Re: Does anyone need service manuals for popular Doosan Machines?
    Hello Darrel. Yes I would like a service manual for the Doosan HP6300. Would appreciate if you could help out.
  2. #62
    Feb 2013
    788
    For the 6300, specifically, I only have an ATC Maintenance manual. (attached)
    I have two service manuals for a very similar machine. (The HM8000) Part numbers will be different, but procedures will be similar. (both attached)
    Attached Thumbnails Attached Thumbnails HM8000_HM8000ALE2A(Alarm).pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  3. #63
    Feb 2017
    hi,
    i need instruction manual for doosan puma 2600L.
    someone please help
  4. #64
    Feb 2013
    788
    Instruction manuals are available through your local Doosan Dealer as a purchasable part.
    To get the specific manual for your machine, you would need to give the local dealer the machine's serial number.
  5. #65
    Feb 2017
    Hi!
    We bought used machine Daewoo PUMA230MB and there is no manuals. The alarm light for chip conveyor is on and I don`t know how to fix it. From program the chip conveyor does not work. Relays are OK. Time relays are pulled out from the beginning, when the conveyor worked. Maybe someone has a manual or a circuit diagram and can share it here?
  6. #66
    2932
    What is the S/N of the machine? What is the make/model of the CNC? What is the make/model of the chip conveyor?
  7. #67
    Feb 2013
    788
    On the placard (where the serial number is) there is a hardware version or an electrical drawing number.
    It is the name of the Electrical Circuit Diagram that was used for your machine. (this number will give me your EXACT electrical diagram, the serial number will bring me dawn to a few possibilities)
    Do you have that number?
    If not, what is the serial number of the machine?
    Side Note: With that number, you can contact your local dealer and purchase new manuals.
    (I can help with the section needed, today...but as they are actual Doosan part numbers, I'm not allowed to send the whole document.)
  8. #68
    Feb 2017
    Hi!
    The machine is Daewoo PUMA230MB Serial No.:P23M0228 Electric drawing edition: P20MH68CA17
    The chip conveyor is made by Woo Jin machinery, Model: PM23 Item No.: L31953116A Serial No.: 0010111
    I want to know whats wrong. The chip conveyor is not in it`s best - push buttons didn`t work from the begining, but it worked from program. Now the alarm light is on and it doesn`t work from program also. It works only when pressed the forward or backward switch in the box, but it`s not an option.
  9. #69
    Feb 2013
    788
    see attached
    Attached Thumbnails Attached Thumbnails Chip conveyor page1.pdf   Chip conveyor page2.pdf
  10. #70
    Mar 2017
    We are in need of a wiring diagram / schematic for a Doosan DMV-3016L. Please advise if you have this or can direct us to a resource.
  11. #71
    Mar 2017
    Post Re: Does anyone need service manuals for popular Doosan Machines?
    Dhardt,
    Can you provide a M code list for an older daewoo DMV 4020 S/n AV5E2287 ?
    If you have it, as well an installation manual and maintenence? I realize this machine is quite old. But anything you have helps.
    Jesse
  12. #72
    Hi!
    I need manual for Operating Control panel Doosan Puma gt2100?
  13. #73
    Jan 2016
    8
    hello, do you have turret disassemble manual for puma 240LM 2005? or something similar like 240mb teardown manual, but without live tooling.
  14. #74
    Feb 2013
    788
    <deleted>
  15. #75
    Feb 2013
    788
    Quote Originally Posted by bemik5 View Post
    You requested a manual for a 240LM, but then said "without live tooling"...Which is it?
    A 240LM is a "240mm workholding", L=long body, M=Milling (aka: Live tooling)
  16. #76
    Jan 2016
    8
    can it be only prepared to live tooling? papers from backdoor said LM.
  17. #77
    Feb 2013
    788
    What is the machine's serial number? ...from the placard on the machine.
  18. #78
    Jan 2016
    8
    my fault it was puma 240LB 2axis only. as you said in your deleted post, it wasn't so hard to disassembly turret. finaly i did it. problem were third pair of tapered pins from back side of curvic coupling. 240mb manual could be used as a quide, i just skip some steps related to live tools. thx
  19. #79
    Aug 2012
    Question Maintenance Manual Lynx 220LM
    Dear Mr. Darryl Hardt
    I need to make a "Maintenance Manual" for the lathe, but in the attached catalogs on the machine, or online, I have not found a manual for maintenance reference. Will you have the manual to share, or a similar maintenance manual related to the machine?
    Thank you very much in advance.
  20. #80
    Feb 2013
    788
    Older MX2000 and MX2500 information
Page 4 of 9 23456
  1. Accurpress Service Manuals
    By FusionMachine in forum Bending, Forging, Extrusion...
    Last Post: 11-12-2012, 12:23 AM
  2. Doosan Daewoo ForkLift Service Manual
    By VikingCAD13 in forum Daewoo/Doosan
    Last Post: 07-02-2012, 06:52 PM
  3. Service manuals
    By sixthearl in forum Haas Mills
    Last Post: 10-11-2009, 08:26 AM
  4. Maintenance or service manuals
    By bigbobomb in forum Fanuc
    Last Post: 11-13-2008, 02:32 AM
  5. Hurco service manuals required
    By Graham S in forum Waterjet General Topics
    Last Post: 12-12-2005, 03:15 AM
