586,299 active members*
3,788 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Does anyone need service manuals for popular Doosan Machines?
Page 3 of 9 12345
Results 41 to 60 of 179
  1. #41
    Feb 2013
    788
    Re: Does anyone need service manuals for popular Doosan Machines?
    The HP 4000 is an older machine.
    I do have manuals for an HP 5100.
    Procedures are similar, but part numbers are different.
    Here is the Mechanical Manual.
    Attached Thumbnails Attached Thumbnails HP51MTE87(mechanics).pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  2. #42
    Feb 2013
    788
    HP 5100
    Here is the Electrical Manual.
    Attached Thumbnails Attached Thumbnails HP51MTE87(electric).pdf
  3. #43
    Feb 2013
    788
    HP 5100
    ATC troubleshooting
    APC Troubleshooting
  4. #44
    Jan 2016
    10
    DEAR MR.HARDT
    THANK YOU FOR SEND THIS MATERIAL
    IT WILL BE GREAT UTILITY
  5. #45
    Jan 2008
    78
    DHardt,
    We are in need of any/all manuals for Puma 8HC-3A. Right now, we have only the parameters for this machine.
    Hope you can help getting manuals - of course we are prepared to pay Doosan for paper manuals.
    Cheers,
    Steve Erickson
  6. #46
    Feb 2013
    788
    Puma 8HC is an older machine (Daewoo,) so I don't have the type of "teardown" manuals or Service manuals that I've been offering here, but Doosan Korea does have the older manuals available for purchase through Doosan America and our network of local Doosan dealers.
    You will need the serial number from the machine, as the 8HC had many variations (It was sold for a long time)
    Where are you located? (USA, Midwest is all that your profile shows)
    You local Dealer is either:
    JM Grisley - MT, ID, UT, Western WY
    Ellison Technologies - MN, CO, SD, ND, NE, IA, Northern NM, Eastern WY, TX, IL, Eastern MO
    Machine tool specialties - OK, KS, Western MO
    Technical Machinery - AR
    I don't have their numbers on me...
  7. #47
    Jan 2007
    46
    Hello, what do you have available for a DNM400 with a 12k spindle?
    I have all the ones that came with the machine but if you have others
    I would like to have those on hand also.
    Thanks, Joe
  8. #48
    Feb 2013
    788
    Quote Originally Posted by joesimmers View Post
    Thanks, Joe
    Here is the Installation manual for a DNM400.
    The Maintenance and Alarm manuals have not been created for a DNM400, but I do have ones for a DNM500. The procedures are the same, but the part numbers are different.
  9. #49
    Feb 2013
    788
    The DNM500 Maintenance manual is available in a previous post to this thread. Attached here is the Alarm manual for a DNM500.
    Attached Thumbnails Attached Thumbnails DNM500_DNM500ALE0A(Alarm).pdf
  10. #50
    Feb 2016
    4
    please help me for Doosan VTL 550 manual and accuracy test chart
  11. #51
    Feb 2016
    4
    please help me for Doosan VTL550 manual and accuracy test chart. i have used machine but i do not know much this machine have accuracy.
  12. #52
    Feb 2016
    4
    i bought old machine i need accurecy chart of this machine which we do not have also need operator manual for this
    other are along with machine,
    thankx for ur support
  13. #53
    Apr 2016
    Quote Originally Posted by dhardt View Post
    Here is a Servo Turret's Alarm Manual, for Vision Drives. (Some Items might apply to ProMotion, also)
    Hello Friends
    Can any one help me with Doosan Old mc Probem with following details (Doosan ol m/c with no Model Plate,Even Fanuc Model is not Indetified)
    Turret Declamp,Clamp and rotation Not Possible-No Coil Voltage On Solinoid Valves
    Chuck Clamp Declamp Not Possible
    Proximity Sensor LED not Glows (Ref,Turret Clamp Proximity LED are not glowing)
    Last week Ive attended this call at that time Turret was rotting randomly in Jog /Index,However wrong Tool no in MDI
    1st Ive checked Declamp /Clamp Coil Voltage was fine ,then ive reduced Hyd Flow which contolled mannual indexing one by one tool but MDI remained same problem (wrong Tool no) but during checking turret some time was not able to declamp at that time ive declamped by pushing Hyd Valve and indexing was ok .However next day Turret Clamp Declamp Chuck Clamp etc was not possible and Voltage on coils was missing.
    Later on I found 2 PCBs on Which One Mosfet D525 was Short and on Second PCB 2 nos of Opto Couplers PC17 was open.but after putting new Components problem was same,Even 24 Voltage of Bridge Rectifier was okay ,Also Step down Transformer on one PCB (opto coupler) was shoing 6.7 Voltage and Rectifier on Same PCB 8 Volts DC.But Problem stil exists.
    Actually I ve never worked on OLD controller and confused either these LED PCB (made by Doosan) are Input/Out Put or One I/p One O/p or relay PCBs .
    If you have any single clue about These PCBs or exact circiut of DC voltage in use for Coils and sensors Pls send or help me with problem.
    Thanks in Advance
  14. #54
    Mar 2016
    36
    daewoo puma 10s
    hi,
    i am a technical engineer, we bought cnc machine, daewoo puma 10s, unfortunatly, its memory card is damaged, i bought a card, and need the machine parameters.
    please help me.
    best regards
  15. #55
    Feb 2013
    788
    Quote Originally Posted by babu_abhishek View Post
    What is the Serial Number of the machine?
  16. #56
    Feb 2013
    788
    Quote Originally Posted by PIRTPAL View Post
    Hello Friends
    Thanks in Advance
    Can you provide ANY information as to WHICH machine it is?
    If nothing else...a few pictures might help identify it...
    If you want information about the Printed Circuit Board, please provide a part or spec number from the board...
    (Please note: we don't fix boards, we replace them...new boards work better than old ones.)
  17. #57
    Aug 2005
    36
    Hi there
    I don't suppose you'd have a maintenance manual, with alarms etc, for a Puma TT 1800, please? We have two of these and it seems the maintenance manuals only have gone walk about.....
    Why, Oh why am I always in trouble?
  18. #58
    Feb 2013
    788
    Quote Originally Posted by pieface View Post
    Hi there
    I recommend re-purchasing the missing Instruction manuals, as they have helpful information in them.
    Regarding teardown and rebuild service manuals for a tt1800, unfortunately I don't have one, but its systems and sections are similar to various other manuals that I do have.
    An older TT1800 has a rear-mounted milling head like that of a Puma 240, a newer TT1800 has a front mounted milling head like a Puma 2100SY.
    There are many other interlinks with other machines, so it would probably be best if we talked over the phone about your specific machine.
    Darryl Hardt
    Doosan Machine Tools America
    Field Service Technician
    973-618-2461
  19. #59
    Jan 2017
    Looking for service manual for lynx220 exchange turret drive and motor.
    Well thank you.
  20. #60
    Feb 2013
    788
    If Servo motor with drive (not hydraulic motor with encoder), then follow directions from the manual for the Puma 240m that is posed up-tread.
Page 3 of 9 12345
  1. Accurpress Service Manuals
    By FusionMachine in forum Bending, Forging, Extrusion...
    Last Post: 11-12-2012, 12:23 AM
  2. Doosan Daewoo ForkLift Service Manual
    By VikingCAD13 in forum Daewoo/Doosan
    Last Post: 07-02-2012, 06:52 PM
  3. Service manuals
    By sixthearl in forum Haas Mills
    Last Post: 10-11-2009, 08:26 AM
  4. Maintenance or service manuals
    By bigbobomb in forum Fanuc
    Last Post: 11-13-2008, 02:32 AM
  5. Hurco service manuals required
    By Graham S in forum Waterjet General Topics
    Last Post: 12-12-2005, 03:15 AM
