Need help deciding which bit to use for your next routing project? Our experts are waiting to help! Here at CNC Router Store, we provide expert advice on which tools you need to get the results you want.
Our customer this week called in to inquire about bits used to add decorative design and finish to wood. Luckily, recently added to the CNC Router Store is a line of incredible routing bits from Dimar. These bits come in all shapes and sizes and can add beautiful finishes to doors, cupboards, signs and countless other wood products.
One example of these bits is the Dimar 139RX-XX Series, with wavy edge bits with ball bearing guide. This bit has two flutes and creates a lovely curved edge design.
Don’t forget to check out our new feed rate calculator on cncrouterstore.ca to ensure that your parameters are set just right for the results you want.
If you felt this was helpful, or have any inquiries of your own, please contact us with your questions and feedback!
Click here to order your own from the Dimar 139RX-XX Series!
Attachment 245638
