586,788 active members*
2,959 visitors online*
    Mar 2008
    14
    how often do you have to edit posts
    Hi we are thinking of getting solidcam at our place, and as I do 90% of the programming offline I have reservations about the software doing all the posts and them working 100%. My boss says that he would like all the editing done through solidcam and nothing done on the machine, I find this impossible to achieve as every time I put the same job back on I have to do at least some editing to get the job spot on, it just seems I will be re-drawing the part to alter a chamfer or editing the post to change a cut depth ect and making a simple edit into a long drawn out procedure. What are your views?
    Dec 2013
    47
    Re: how often do you have to edit posts
    Ive worked with a few cam systems. Including the newest mastercam for Soliworks. I love solidcam hands down.
    Once you have a post set up for your machine you will never need to edit it or at least I dont ever need to edit mine. Unless I change features. Like adding 4th axis 5th axis , coolant features stuff like that. The programs is solid and worth it. Just make sure your PC is up to it . Solidcam needs a decent computer set up to be on. Otherwise it will crash and freeze. I have a laptop dedicated to Solidworks and Solidcam only . Its a quad core AMD with a terabyte of harddrive space. Before that it was on an older computer that couldnt handle it. Big change when I switched.
    Your Boss and programmers will be happy with the program I was.
    Goodluck
    Oct 2013
    153
    Hope that people barking on the software crash will read this post
    Oct 2007
    499
    It took me a while, probably about a year, to get my 5X post for our Hermle C20U to state where I will send posted code straight out to the machine and expect no CAM rework. In the early months I was editing the post almost every other day but this reduced and now I make edits to the post about once every year or two (usually because SolidCAM has changed some functionality in the CAM output).
    I am a little puzzled by your comment about 'altering a chamfer'. Your post will not prevent things like that - if you program it right and it looks good in SolidVerify but the chamfer is too deep or shallow when it is cut, then it is a setting issue that can be overcome by using a wear offset or changing the tool length or radius compensation. Producing parts on a CNC is a partnership between the programmer and the set-up person. We have a policy here of anything that can't be controlled on the machine by using tool or work offsets MUST be go through the CAM - to do anything else in 5 axis work is courting disaster. Some of our old school programmers balked at this but once they'd had a nasty scare or worse still, a crash, due to using 'on machine edits' they soon came around.
    Mar 2008
    14
    Hi yes was jus making an example, we do a lot of intricate work that sometimes involves going over the part again to knock off burrs created by milling ect or after screwcutting.
  1. How to edit posts
    By ssoptical in forum BobCad-Cam
    Last Post: 03-13-2009, 11:50 AM
  2. edit posts manual
    By manuelc149 in forum Mastercam
    Last Post: 10-03-2007, 04:14 AM
