Re: UCCNC owners and support thread
Originally Posted by
A_Camera
The apply button is not redundant, it is good to have if you realize that you have made several configuration changes, applied tested but you are not happy and just want to revert to the previous one. If you have saved the configuration you can't revert, you have to redo back everything. By not saving, just applying, you can just close and start up and you are back at the previous config. I hope CNC Drive is not going to remove the apply button.
Unfortunately your confusing the apply button with a revert button. The apply button only tells the system to process the current settings it doesn't give you a way to go back to a previous setting that's a previous / revert button, once the apply button is pressed the settings are what they are. As I explained in my previous post an apply button is optional based on how the programmer tests for errors.
If my post is missing an 'nt you might have to add it yourself.
