Originally Posted by
probinson
OK Let's recap:
1) You have a problem with the Z retract in one place in a specific program.
2) You tried a few things with the software, including loading an older copy that used to work to check for accidental code errors, but the problem persists.
3) You try some suggested fixes for common problems and that didn't help.
4) It's now time to pin down whether it is a hardware or software issue so you don't keep poking around blindly.
a) A good place to do that it at the driver outputs. If the drive signals are good the problem is somewhere in the wiring or the mechanics. If the drive signals are corrupt then the problem is somewhere from the driver output toward the actual code.
b) The appropriate piece of test equipment is an oscilloscope but if you don't have an oscilloscope you can use headphones to perform the task.
This was intended as a quick way to perform the test using things you have at hand but has morphed into hijacking the tread and I apologize for that.
So, let's confirm the symptoms and get back to actually finding the problem.
Are these true statements?
The machine runs other programs just fine.
It is only this program and only this one retract that exhibits missed steps.
