587,035 active members*
2,903 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Does tool life vary with interrupted cuts to continuous cuts
    Jan 2011
    24
    We run a production job with volumes of 10000-15000 per month( Turning job ). Cast iron machining. We are getting a tool life of 40 parts per edge. I was wondering if intermittent cut on the job has consequences on my tool life. Also does improper work holding affect tool life.
    Here to learn, share and stay.
    Mar 2008
    14
    Re: Does tool life vary with interrupted cuts to continuous cuts
    Vastly affect tool life, you need to speak to your tooling supplier rep and get the appropriate grade and geometry for intermittent cutting. You need to hold your component properly also as that has a large influence on tool life and also surface finish and repeat ability of your part.
    Apr 2012
    43
    What ianglover said x2. Also, if you can you are better off to use a tough grade to get through the interrupted cut, then come back with a higher productivity grade and fly through it.
    Apr 2012
    90
    Does a bear **** in the woods?
    Jan 2011
    24
    Haha.. I am that kinda person even if I know that it is the most likely answer, I would like to hear it from experienced folks.. It's annoying for others, but that's okay.. I am at peace to have known it from people with exp. Also with the skill level around me.. I can't ask ppl where I work. They are like champions for misguiding and they take you for a ride if you are edgy..
    "The stupidest question is a question that has not been asked"
    Sep 2013
    147
    Quote Originally Posted by AARONT View Post
    Not a polar bear lol
  1. 4th axis tool path depth cuts?
    By clivefx in forum Mastercam
    Last Post: 07-20-2011, 09:36 PM
  2. Same tool - different cuts ?
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 07-25-2010, 08:10 PM
  3. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  4. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
  5. M00 within cuts with same tool
    By shawncnelson in forum Mastercam
    Last Post: 05-05-2006, 12:38 PM
