586,455 active members*
3,399 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Turning and drilling copper
    Jan 2014
    27
    Hello, I'm having some trouble finding good speeds and feeds for copper. I'm working with .500" bar stock. Does anyone have some general guidelines for running this material? Thanks.
    Mar 2008
    14
    Re: Turning and drilling copper
    Turn it a lot on sliding heads, generally you need to peel it off, I would try 90m/min and a feed rate of .015-.02mm/rev, and you need a good coolant supply, I use neat cutting oil. I use Seco DCMT11T304 F1 in CP500. Or alternatively use alum geom. drilling use a carbide drill and keep the revs down, slow feed and small pecks.
    Jan 2014
    27
    Ok, thanks. I'll try this. I've been putting this material off because I broke a drill.
    Sent from my SPH-L720 using Tapatalk
    Sep 2014
    5
    An old school toolmaker trick is to sharpen the tip of your drill slightly off centre so it drills a bit oversize, then in any non errous metal use a good fluid even a few drops of kerosene works just enough to keep the tip lubed so debris does not gum up or stick to the drill
  1. Drilling Copper
    By Shea al'Thor in forum MetalWork Discussion
    Last Post: 02-21-2013, 04:34 AM
  2. drilling copper
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 08-26-2011, 05:08 AM
  3. drilling copper
    By vbundy in forum MetalWork Discussion
    Last Post: 11-03-2009, 05:35 PM
  4. Copper Turning, C18200
    By Tenextoolco in forum MetalWork Discussion
    Last Post: 03-03-2009, 11:54 PM
  5. Drilling copper
    By jerry1122 in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2008, 07:33 PM
