I have been working in machine shops for about 23 years. I have always worked as an employee or as much as a Forman. Never had to seek out the work. After the last shop I worked for shut down, I have been trying to make ends meet working part time for a small machine shop, owned by an older gentlemen and his son. It has been left up to me to find work enough to make it work.
I have Parametric modeling software, for doing design work or for receiving it, as well as CAM software for 2 to 4 axis programming for CNC Mills and lathes. The facility has a HAAS VF machining center. (X 30 Y16 Z18.) A Mazak quick turn Lathe (X=8.INCH diameter. Z 19.) as well as manual Mills and lathes.
If anyone has any machine work that falls within these machine capabilities or if you can point me in the right direction to some potential work I would greatly appreciate it.
My Email is.
[email protected]
The shop where I work is called Glenfield Inc. And is located at
45 England Drive Batesville AR 72501-9090. Thank you for your interest.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
