586,347 active members*
3,621 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 4flute vs 2 flute indexables, and large holes thru thick plate!
    Dec 2007
    126
    We bore a lot of 1" thick plates with 3-4" diameter hole, currently using 2 flute 1" indexable mills to do it, after drilling 1" hole for access. Looking for something faster and quieter ideally!
    Thinking 3 or 4 flute should be quieter, as at least one insert would be in contact with material almost all the time. We run a spiral feed out for chewing the hole into chips, running 70-80% of cutter diameter.
    Never used one, annular cutter maybe? Not finding any drills over 2" diameter.
    Would 4 flute be quieter than 2 flute? We're running at 2400 rpm feed at 25IPM, cut depth of .18-.25" per pass
    Jul 2014
    18
    Re: 4flute vs 2 flute indexables, and large holes thru thick plate!
    No drill. Use a square shoulder inserted endmill/facemill. 1-1/2" for the 3" bore. 2" for the 4" bore. Helix through the material from solid.--Helix - not spiral. More flutes would be better. Use air to evacuate the chips. Then interpolate the diameter with the same tool once you are thru.
  1. 1/4" to 10 mm thick steel plate
    By kdoney in forum RFQ (Request for Quote)
    Last Post: 12-15-2011, 07:35 PM
  2. 1 Sub Plate 216 holes
    By Lee in Texas in forum Employment Opportunity
    Last Post: 03-05-2011, 09:06 AM
  3. Simple 1/4" thick 6061 plate
    By Aaron92SE in forum Employment Opportunity
    Last Post: 05-16-2008, 10:47 PM
  4. Cutting thick steel plate
    By Woodenspoke in forum MetalWork Discussion
    Last Post: 07-12-2007, 05:58 AM
  5. Cutting Large Diameter Holes in Aluminum Plate
    By barkster in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2004, 11:44 AM
