586,359 active members*
3,497 visitors online*
    Jul 2014
    Mystery Cooling Fan Wire
    I have a 2000 HAAS VF2 and I am replacing the backup battery. I was removing the metal shroud protecting the circuit boards and I accidentally unplugged the wire to the fan that is bolted to that shroud. I have not been able to figure out where that wire was plugged. Does anyone out there have any suggestions?
    Thanks in advance!
    Aaron
    Jul 2014
    Re: Mystery Cooling Fan Wire
    I found it. It plugs into the board that is off to the right of the fan shroud. A little plug labeled something cryptic like "fan".
    Mar 2010
    1852
    Knew you would find it! :cheers:
  1. Replies: 0
    Last Post: 06-02-2014, 07:24 PM
  2. Mystery to Arc OK loss
    By MeisterWerks in forum Waterjet General Topics
    Last Post: 01-28-2013, 08:18 AM
  3. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
  4. R&P Mystery
    By Treischl in forum DIY CNC Router Table Machines
    Last Post: 06-05-2011, 01:56 AM
  5. Mystery
    By SteveY in forum Solidworks
    Last Post: 10-25-2010, 05:50 AM
