Hello, can someone give me quick answer:
I am working with Elumatec SBZ140 milling machine, the question is that I have three parameters which describes my cutter:
RPM, speed of moving to the side and speed of depth, but in the machine I have RPM, feed rate and gear ratio-1.
So ok RPM = RPM, speed of moving to the side means feed rate? So where I can input depth speed? To the gear ratio..? I don't think so.. THX for help
I am also using EluCAD software and in tool's parameter I have: RPM, Working feed (= side speed?) and Immersion feed (=depth speed?)?
