587,030 active members*
4,008 visitors online*
Page 2 of 3 123
Results 21 to 40 of 44
  1. #21
    Mar 2013
    20
    Re: BT30 spindle built from scratch, with ATC possibility.
    That's awesome man! Good luck!
    Time for another update! A colleague helped me in the CNC-grinder. Grinding the spindle housing, outside and the front bearing seat is now done. Will grind the back bearing seat hopefully next weekend.
    Attachment 247738
    Doing some test fitting.
    Attachment 247740
    Attachment 247742
    Now it's time to grind the spacer-rings to the correct size, not today tho.
    Attachment 247744
    So I did some run-out testing(without the roller bearing), the run-out on the back bearing seat was around 0.02mm, and the run-out 200mm away from the tool taper was 0.02mm. Note that I didn't adjust the run-out in the AC-bearings when testing it today, when I do the final assembly I should be able to get lesser run-out on the back bearing seat and therefore lesser run-out on the tool taper. I'm still aiming for a maximum run-out of 0.01mm, 200mm away from the taper.
    Here's a video showing the run-out testing.
    https://www.youtube.com/watch?v=EsOjSYLWJHc
    Still a lot of work left, but I'm getting closer to a finished spindle!
  2. #22
    Mar 2013
    20
    Made myself a hook spanner for the KMT nuts.
    Attachment 248508
    Me and a colleague were gonna grind the back bearing seat after work yesterday but the belt to the spindle weared out, so were grinding it next week instead.
    Attachment 248510
    Drilled and tapped some holes on front of the spindle housing.
    Attachment 248512
    Looks gorgeous imo!
    Need to get the roller bearing on there ASAP! :P
    Attachment 248518
  3. #23
    Aug 2006
    1602
    Wow - what a fantastic project! Excellent work!
  4. #24
    Mar 2013
    20
    Thanks man!
    Me and a colleague ground the back bearing seat on the spindle housing yesterday. The housing is now complete.
    I also ground the spacer ring to tolerance, which sits below the roller bearing.
    Attachment 249450
    Attachment 249452
    I might do some test assembling today, we'll see.
  5. #25
    Mar 2013
    20
    Made a keyway groove in the spindle today.
    Attachment 250124
    Attachment 250126
  6. #26
    Mar 2013
    20
    Another test assembly today, might be one of the last test assemblies before the finished spindle! All that's left for the rotating parts is the labyrinth seal above the roller bearing, might start with that next week.
    Here's a vid showing me measuring some run-outs or the spindle.
    https://www.youtube.com/watch?v=zZqFSKEpEjM
  7. #27
    Mar 2004
    392
    Work of art.
  8. #28
    Oct 2010
    1189
    Cool i would also like to have your machines to build one ...
  9. #29
    Mar 2013
    20
    Heh, thanks guys!
  10. #30
    Mar 2013
    20
    Lathed the labyrinth seal for the roller bearing yesterday. They're made of Uddeholm Stavax for it's rust-resistant properties, will be hardened to 52HRC for extra stiffness.
    I also bored 6 holes in the outer ring, but no pics of that.
    If everything goes as planned, I'll have them back before next weekend.
    Attachment 251268
    Attachment 251270
  11. #31
    Oct 2014
    8
    Hi dear Mr3D,
    sorry for my poor english,
    I see your very interesting work on youtube and after some search find your post here. dear Mr3D I want to build a spindle like yours but as my English is not good I can't find the proper information and plan, could I ask you to help me to find the plan and cad file of this spindle?
    Thank you so much
    Regards
  12. #32
    Mar 2013
    20
    Hey man, thanks for being interested in my spindle!
    The design isn't something I found on the net, it's my own design. Tho, I won't release the 3D-files, I've already published a section view of the design(first pic of this thread). If I were to make another spindle right now I would make some design changes to the gripper, beside that nothing major. Maybe make it slightly longer(tho I can't manufacture a spindle shaft longer than what it is now.)
    If you want to make your own, you have to make your own 3D model, but looking at my section view should make that kinda easy, when you design your own spindle, you could take into account the machines that you have access too, that's what I did. Good luck with the spindle build, man! When you make a build thread, share a link here.
    On another spindle-work-related note, I thought the labyrinth seal for the roller bearing would get back from hardening before today, but it didn't. I won't have time next weekend so there's another 2 weeks before next update... :drowning:
  13. #33
    Oct 2014
    8
    Thank you so much dear Mr3D for your replying.
    It's hard for me to design my own, I'm completely newbie in designing and these day I trying to follow some step by step guide to build my own machine like: CNC lathe and CNC router.
    so if there is any way for me to take your design in detail (buying it) you already have my email, let me know.
    your spindle is absoloutly interesting.
    Thank you so much again for replying
    Siavash
  14. #34
    Mar 2013
    20
    If you want to build a router you have to make your own CAD model, so drawing a spindle shouldn't be hard. In fact basically the spindle design is just a profile revolved around an axis, easy to make even for a beginner.
    Thanks for your offer, but the 3D-model isn't for sale.
    I think this thread should be a great start for your build. I vote for trial and error tho, that's the best way of learning stuff, the best thing about a project isn't the result, it's about the road there.
    Tho, if you have some questions about some of the design choices I made, feel free to ask them! E.g. why I did this instead of that.
  15. #35
    Oct 2010
    1189
    Wubian Look at grabcad maybe someone sell you drawing but m3d is right the road is as important as the result ,.. I also adjust an iso30 spindle for toolchanger ,..
  16. #36
    Jul 2013
    14
    Hi Mr3D,
    I tried to contact you via PM with some questions about my ATC spindle design, but it says that you have blocked PM messages. Could you please contact me?
    Thanks a lot!
  17. #37
    Mar 2013
    20
    Hey man!
    Something's weird here... My settings is set correct, 5min ago I saw 2 PM's from wubian, but now their gone... I'll try sending one to you.
  18. #38
    Jul 2013
    14
    Hi!
    I received your message, but can´t send mine. Here´s the screenshot of what is going on. Maybe if you can PM me your email adress?
  19. #39
    Mar 2004
    1306
    Fabulous work you have done there.
    I would be happy to get my home made spindle up to the quality of the first one you made.
    Mark
  20. #40
    Oct 2015
    Ola.
    Tenho interesse em fazer um igual, vc vende os desenhos para montar um ?
    Abraço.
Page 2 of 3 123
  1. Home Designed Scratch Built CNC Lathe
    By Chrisjh in forum Videos
    Last Post: 11-07-2013, 09:40 PM
  2. My scratch-built plasma table
    By grahamcowan in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-19-2013, 05:21 PM
  3. Looking for Specs for a scratch built lathe
    By breathe in forum Vertical Mill, Lathe Project Log
    Last Post: 06-16-2011, 12:56 PM
  4. Mini 3 Axis CNC scratch built
    By Seraph in forum Vertical Mill, Lathe Project Log
    Last Post: 03-19-2008, 09:58 AM
  5. Advice on Small CNC Mill - From Scratch or Pre-Built?
    By DrCNC in forum Benchtop Machines
    Last Post: 11-30-2006, 01:29 PM
