586,682 active members*
2,667 visitors online*
    Jul 2014
    Unhappy Speeds and feeds
    I make a 3.5 in. bevel gear out of C954 AL BRZ on a regular basis. I surface the gear teeth on a 4 axis VMC. I can cut them all week long with the same end mills @ 6K rpm and 35 ipm. My customer wants some out of 1040 CRS. Roughing the stock is no problem, however finishing is a different matter. I'm using an ALTIN coated 1/8 ball mill @ 6K rpm and 7.5 ipm. My semi-finish pass is taking approx. .005 stock off. I can only do about 5 of the 15 teeth before the end mill goes away. Any advise for speed and feed? Thanks
    Jul 2014
    18
    Re: Speeds and feeds
    Your feed rate is very low. 0.00125 per revolution. This will cause the tool to wear prematurely. Assuming not plunging the tool into a corner and good coolant supply (Air preferred... mill steel dry!!) Safely double your feedrate to start. I would run this tool at 12,000 rpm and 24 IPM and increase feed from there. The important thing is NOT to recut the chip. Use plenty of air to get it out of the way.
    Jul 2014
    Thanks for the info. I have an 8K spindle, using your numbers I came up with .0005 IPT. So if I run at 7200 RPM x 4 flutes x .0005 IPT that comes out to 14.4 IPM, correct?
    Jul 2014
    18
    That is correct. If the depth of cut is only at the tip.... then increase from there to account for chip thinning. Ball mills are their own animal. Feed is dependent on axial DOC.
    Aug 2014
    12
    Find out the recommended surface footage of that brand of tool you are using. take the surface footage x 3.82 / dia.. this gives you the recommended rpm.. take the rpm x ipt x # of flute.. thats your feed rate..
    If you have a decent end mill the surface footage will be about 200 with a chip load of about .001 per tooth..
    s = 6112
    f = 24.
    Apr 2012
    90
    Go 8000 rpm and 48ipm if you are using a 4 flute ball increase feed if you are able to. You can use coolant if you have high pressure flood otherwise cut dry with air for chip removal.
  1. Feeds/Speeds
    By wwendorf in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2013, 03:50 PM
  2. 303 Feeds and speeds
    By brento in forum Uncategorised MetalWorking Machines
    Last Post: 10-26-2011, 10:53 PM
  3. Feeds and speeds help please!!!
    By native34 in forum Benchtop Machines
    Last Post: 12-12-2008, 06:05 PM
  4. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  5. Speeds and Feeds
    By CLP CORP. in forum WoodWorking Topics
    Last Post: 12-07-2007, 07:38 PM
