586,358 active members*
3,451 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Current set resistors
    Dec 2012
    12
    Hi all,
    I am using the Gecko G540 and all 3 steppers are Nema 23 387ozin 3.5amp. I have read on numerous posts and in the Gecko manual that at 3.5amps I don't need to use current set resistors.
    If I don't the G540 won't go into idle. The only down side of this is that the steppers will run hotter.
    I can't find anywhere that states whether the increased operating temperature will be a problem. Can I safely run without current set resistors?
    I can't find 3.5a resistors but I do have 3.6a ones, Is it ok to go a bit higher on the resistor value or a bit lower?
    Thanks.
    Feb 2007
    4553
    Re: Current set resistors
    Cookie28b
    3.48K should be fairly easy to locate and the current reduction will work correctly.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2012
    12
    Ok, thanks Jeff, will go with the 3.48k.
    Cheers.
  1. Current Set Resistors
    By dpgoldberg in forum CNC Machine Related Electronics
    Last Post: 10-23-2010, 07:23 PM
  2. Current Set resistors
    By xitian in forum Gecko Drives
    Last Post: 06-06-2007, 04:23 AM
  3. Sensing Resistors vs Current limiting Resistors
    By whitney in forum Hobbycnc (Products)
    Last Post: 11-06-2006, 06:29 AM
  4. current set resistors
    By planescott in forum CNC Machine Related Electronics
    Last Post: 03-02-2006, 01:10 PM
  5. What current set resistors do I need.
    By Apples in forum Gecko Drives
    Last Post: 08-31-2005, 08:53 AM
