586,475 active members*
3,439 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Hitachi Seiki 4NE-600 LATHE STARTUP SEQUENCE
    Jul 2014
    I purchased a Seiki 4NE-600 lathe on an auction.
    Just powered it up and can not get servos to start.
    I have 3 phase proper as Hydraulics are working under pressure.
    Tail stock has pressure on return, but not on forward.
    I do not think I am getting past all the safeties.
    I replaced a missing estop at main panel wit 2 of Normally closed contacts.
    It has an red panel display, maybe late 80's model.
    Tape reader buttons have been cleaned and can not read what they should say.
    Any help or suggestions are appreciated.
    Any manuals would be appreciated as well, I have only a sheet with parameters with the machine.
    Dec 2009
    539
    Re: Hitachi Seiki 4NE-600 LATHE STARTUP SEQUENCE
    Hello, was the 4NE under power when you bought it and was it running?
    John
    Mar 2012
    If you haven't solved your problem yet. Try tail stock return M26 and low gear M40. I have the manuals for a Kia version 10 TF control, it is the same as a Hitachi I had a Hitachi previously.
    Apr 2016
    Did you find the problem? We have bought the same lathe and have the same problem.
    Regards
    Tim
    Mar 2019
    Quote Originally Posted by pci1 View Post
    Sir on panel side there is led display board type 29 and input check status
    - - - Updated - - -
    I have manual of this machine
    May 2019
    Quote Originally Posted by Abhi888 View Post
    - - - Updated - - -
    Hello,I think that we have the same machine ,
    and I suupose that in this panel is loaded some data
    like timers , counters , keep relay ...
    At the back of the door It have a card with batteries ,
    these batteries are shur down and I suppose that we lose the
    data which is loaded there ..
    Do you have any manuals how to load this data and
    list with these parameters ?
    Thank you
  1. hitachi seiki cnc lathe
    By haltech in forum Community Club House
    Last Post: 12-15-2013, 12:05 AM
  2. CNC Lathe Hitachi seiki
    By tphan in forum Community Club House
    Last Post: 08-09-2012, 07:08 AM
  3. Hitachi Seiki lathe
    By PMWTIM in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2011, 03:13 AM
  4. HITACHI SEIKI 3NE 300 LATHE ALARM 401
    By jordan123 in forum MetalWork Discussion
    Last Post: 03-31-2011, 02:57 AM
  5. HITACHI SEIKI HT-20 Lathe?
    By stealth1 in forum Mach Lathe
    Last Post: 01-10-2011, 09:17 PM
