586,389 active members*
3,013 visitors online*
Results 1 to 8 of 8
    Oct 2009
    4
    Mazak VCN 510-C motor encoder question
    We are facing an issue with the spindle motor (Mitsubishi).
    We changed the bearings as we got an alarm
    for spindle malfunction,
    and as a result there is an error on the encoder.
    When we try to rotate the spindle (even by hand)
    we get immediately an alarm and emergency stop.
    What I am looking for is some information on the encoder
    of a sj-4-vks15-13zt motor.
    All I can read is CM16AC. The rest are sealed.
    Do they sell these separately or together with the whole motor?
    Do I have to contact Mitsubishi or Mazak for this?
    Any idea/suggestion?
    Thanks a lot in advance
    Dec 2007
    300
    Re: Mazak VCN 510-C motor encoder question
    Contact Mitsubishi they have an office near somewhere.
    24223
    Not sure on that motor, but if it is the PG type, you have to align the quadrature pulses on the older type, done using a double beam 'scope.
    You can tell the PG type by the toothed gear type wheel.
    Al.
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERSOF PRECISION BEARINGS
    MAINLYAPPLY FOR CNC AND MACHINE TOOL AND OTHER PRECIAION MACHINARY , WHICH ARE MAKE OF WAFANGDIAN TIANJIU BEARINGS TECHNOLOGY CO.,LTD.
    WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THEPRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    WE HOPE CAN CORPORATION WITH YOUR COMPANY.IF ANY RELATED INQUIRY,PLEASE FEEL FREE TO CONTACT WITH US.
    WE CAN ALSO SUPPLY BEARINGS SAMPLE FOR YOUR AT FIRST.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    THANK YOU !
    REGARDS!
    Lixingwen
    Wafangdian Tianjiu Bearings Technology Co.,Ltd.
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: 瓦房店天久轴承科技有限公司(原 瓦房店重型轴承研究制造有限公司)
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
    Sep 2008
    93
    Quote Originally Posted by ghandee View Post
    this spindle motor has a PLG,
    adjust procedure
    http://www.meau.com/Files/BNP-B8827-...00001039000000
    Oct 2009
    4
    Thanks for the effort and the answers.
    Still no news on the problem, or the risk is too high to install a new encoder
    without being 100% sure that it's the correct one.
    Mantenim, I cannot open the link for some reason
    Sep 2008
    93
    i atached a procedure for adjust PLG for serie DH.
    please check your spindle drive is MDS-DH, or MDS-CH, or MDS-C1. if your spindle drive is DH, this is the procedure.
    Attached Thumbnails Attached Thumbnails Mazak MDS-D-DH PLG ADJUSTMENT WITH TS5691.pdf
    Oct 2009
    4
    Mantenim, thank you sooooo much!!!!
    We came tried repositioning the sensor and it worked. For a while.
    The signal was within the limits of the diagram described on the pdf you provided.
    We also run the motor on open loop (ie. without using the encoder)
    and it worked fine. No strange sounds, no nothing.
    We came to the conclusion that it is due to the circuit board that comes with the encoder.
    We will try to find another to replace it.
    The distributor here suggests that the only solution is to replace the complete motor/encoder system
    which is out of question, since the motor is fine.
    Thank you very much for the help provided here.
    I will keep you informed about the results.
    Be well
  1. HOW TO CHANGE ACTIVE ENCODER FROM LINEAR SCALE TO MOTOR ENCODER IN SIEMENS 840D.
    By sandeepmb123 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-02-2014, 08:05 PM
  2. Question about Encoder
    By Jackal66 in forum Servo Motors / Drives
    Last Post: 07-05-2010, 09:30 PM
  3. new DC-motor with encoder
    By maycom in forum CNC Machine Related Electronics
    Last Post: 01-01-2008, 03:07 PM
  4. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
  5. Clifton motor encoder question
    By Gnome in forum Servo Motors / Drives
    Last Post: 02-07-2005, 03:18 AM
