586,465 active members*
3,759 visitors online*
Results 1 to 12 of 12
    Mar 2008
    13
    Automatic tool length measurement
    Hi everybody.
    Now do automatic length measuring instruments, and then writing it to a table.
    Code length measurement works. That is:
    Code:
    #include "KMotionDef.h"
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    #define Zaxis 2
    main()
    	int FixtureIndex,Units, TWORD, HWORD, DWORD;
    	double NewToolLength,OriginOffsetZ,AxisOffsetZ;
    	double Machinex,Machiney,Machinez,Machinea,Machineb,Machinec;
    	double P0,P1;
    	SetBitDirection(0,0); // для оси Z
    	//сначала ось Z - 5000 имп/мм
    	Jog(2,-4000);
    	while (!ReadBit(0)) ;
    	Jog(2,0);
    	P0 = chan[Zaxis].Dest;
    	P1=P0+1000;
    	MoveAtVel(Zaxis,P1,2000);
    	while (ch2->Dest < P1) ;
    	Jog(2,-1000);
    	Jog(2,0);
    	GetMiscSettings(&Units, &TWORD, &HWORD, &DWORD);
    	GetFixtureIndex(&FixtureIndex);
    	GetOriginOffset(&OriginOffsetZ, FixtureIndex, Zaxis);
    	GetAxisOffset(&AxisOffsetZ, Zaxis);
    	GetMachine(&Machinex,&Machiney,&Machinez,&Machinea,&Machineb,&Machinec);
    	// Compute Tool Offset to make DRO zero when Tool Length selected and enabled
    	// Since Machine = DRO + OriginOffset + AxisOffset + ToolOffset
    	// Set DRO = 0 and solve for ToolOffset
    	NewToolLength = RoundToReasonable(Machinez - OriginOffsetZ - AxisOffsetZ,Units);
    	// Change Currently Selected Tool Length
    	SetToolLength(TWORD,NewToolLength);
    But I have a different diameter tools. And I need to do offset of X and Y to the edge cutter hit the center of the sensor.
    How to read the offset of X and Y from the tool table?
    Sincerely, Alexander.
    May 2006
    4047
    Re: Automatic tool length measurement
    Hi Alexander,
    I think we will need to add in KFLOP to PC commands like SetToolLength for X and Y Tool Offsets. Or is it Diameter that you need?
    What exactly would you like to do?
    Regards
    TK
    TK
    http://dynomotion.com
    Mar 2008
    13
    Hi Tom.
    Thanks for the answer.
    I need to read a variable from a table tool radius or offset. No matter what.
    I want to when measuring the length of the tool was its automatic shift from the center of the sensor. Need to measure the edge cutter.
    Mar 2008
    13
    Tom hello.
    Please help solve the problem.
    May 2006
    4047
    Hi Alexander,
    We have added functionality for Get/Set Tool Diameter and Tool XY offsets.
    Code:
    // Request a Tool Diameter, answer will be placed at persist offset
    int GetToolDiameter(int index, double *Diameter)
    // Change a Tool Diameter, value to be passed up is at specified persist offset
    int SetToolDiameter(int index, double Diameter)
    // Request a Tool X offset, answer will be placed at persist offset
    int GetToolOffsetX(int index, double *OffsetX)
    // Change a Tool X offset, value to be passed up is at specified persist offset
    int SetToolOffsetX(int index, double OffsetX)
    // Request a Tool Y offset, answer will be placed at persist offset
    int GetToolOffsetY(int index, double *OffsetY)
    // Change a Tool Y offset, value to be passed up is at specified persist offset
    int SetToolOffsetY(int index, double OffsetY)
    Here is an example of how to use them:
    Code:
    	GetToolDiameter(TWORD,&ToolDiameter);
    	GetToolOffsetX(TWORD,&ToolOffsetX);
    	GetToolOffsetY(TWORD,&ToolOffsetY);
    	printf("Original Tool #%d Diameter=%.17g OffsetX=%.17g OffsetY=%.17g\n",
    		TWORD,ToolDiameter,ToolOffsetX,ToolOffsetY);
    	SetToolDiameter(TWORD,0.1);
    	SetToolOffsetX(TWORD,0.2);
    	SetToolOffsetY(TWORD,0.3);
    	GetToolDiameter(TWORD,&NewToolDiameter);
    	GetToolOffsetX(TWORD,&NewToolOffsetX);
    	GetToolOffsetY(TWORD,&NewToolOffsetY);
    	printf("New Tool #%d Diameter=%.17g OffsetX=%.17g OffsetY=%.17g\n",
    		TWORD,NewToolDiameter,NewToolOffsetX,NewToolOffsetY);
    That prints:
    Original Tool #0 Diameter=0 OffsetX=0 OffsetY=0
    New Tool #0 Diameter=0.1 OffsetX=0.2 OffsetY=0.3
    Can you do the rest yourself?
    To make use of this functionality add and patch the following files in Test Version V4.33c
    http://dynomotion.com/Software/KMotion433cc.exe
    Files are located here:
    Index of /Software/Patch/AddKMotionCNC_GetSetToolDiamXYOff_V433c
    Copy KMotionCNC.exe to the KMotion/Release Directory
    Copy PC-DSP.h to the DSP_KFLOP directory
    Copy KflopToKMotionCNCFunctions.c to the C Programs Directory
    Copy ToolTableSetDebug.c to the C Programs Directory
    Please provide feedback if problems are encountered.
    Regards
    TK
    Mar 2008
    13
    Thank you very much Tom!
    When I conducted an experiment, it will unsubscribe here.
    Mar 2008
    13
    Hello everyone.
    Tom, thank you.
    Everything works. The result was the following code:
    Code:
    #define Zaxis 2
    #define Xaxis 0
    #define Yaxis 1
    #define XaxisCNTS_mm 3937.0078740157
    #define ToolSensorPin 0
    #define ToolSensorX 992000
    #define ToolSensorY 400000
    int DoPC(int cmd);
    int DoPCFloat(int cmd, float f);
    int DoPCInt(int cmd, int i);
    int MsgBox(char *s, int Flags);
    int SetVars(int poff, int varoff, int n);
    int GetVars(int varoff, int n, int poff);
    main()
    	double NewToolLength,Length,OriginOffsetZ,AxisOffsetZ,ToolOffsetX,ToolDiameter;
    	double P0,P1,A0,A1;
    	int GetToolOffsetX(int index, double *OffsetX);
    	int GetToolDiameter(int index, double *Diameter);
    	SetBitDirection(ToolSensorPin,0); // sensor input - вход датчика
    	// Stop the spindle and lift tool - Останавливаем шпиндель и поднимаем инструмент
    	ClearBit(153); // Stop spindle
    	ClearBit(154); // Stop spindle
    	Delay_sec(0.5);
    	MoveAtVel(Zaxis,1300000, 40000);
    	while (ch2->Dest < 1300000) ;
    	//Ansver "ToolChange"
    	printf("Original Tool #%d Diameter=%.17g\n",
    		TWORD,ToolDiameter);
    	int Answer;
    	//int tool = persist.UserData[9];  // value stored is actually a float
    	char s[100];
    	sprintf(s,"Change to Tool diameter D=%.17g\n",ToolDiameter); //sprintf(s,"Change to Tool diameter D=%d",ToolDiameter);
    	Answer = MsgBox(s,MB_ICONEXCLAMATION);
    	//if (Answer != IDOK)
    		DoPC(PC_COMM_HALT);
    	// Offset X - перемещаем инструмент к датчику и делаем смещение по Х
    	printf("Original Tool #%d OffsetX=%.17g\n",
    		TWORD,ToolOffsetX);
    	MoveAtVel(Xaxis,ToolSensorX-ToolOffsetX*XaxisCNTS_mm,40000);
    	MoveAtVel(Yaxis,ToolSensorY,40000);
    	while (ch0->Dest != ToolSensorX-ToolOffsetX*XaxisCNTS_mm) ; // ПРОВЕРИТЬ УСЛОВИЕ!!!!
    	while (ch1->Dest != ToolSensorY) ; // ПРОВЕРИТЬ УСЛОВИЕ!!!!
    	//omit the Z-axis of sensor - опускаем инструмент на датчик
    	Jog(Zaxis,-10000);
    	while (!ReadBit(ToolSensorPin)) ;
    	Jog(Zaxis,0);
    	P1=P0+100000;
    	MoveAtVel(Zaxis,P1,20000);
    	Jog(Zaxis,-1000);
    	Jog(Zaxis,0);
    	// calculate the length of the instrument and record in the table
    	// вычисляем длину инструмента и записываем в таблицу
    		// Lift tool - Останавливаем шпиндель и поднимаем инструмент
    	printf("Units=%d T=%d  H=%d  D=%d\n",Units, TWORD, HWORD, DWORD);
    	printf("Current Tool Length is %g\n",Length);
    	printf("Fixture Index = %d\n",FixtureIndex);
    	printf("Origin Offset Z = %g\n",OriginOffsetZ);
    	printf("Axis Offset Z = %g\n",AxisOffsetZ);
    	printf("Machine Coordinates %.17g %.17g %.17g %.17g %.17g %.17g\n",Machinex,Machiney,Machinez,Machinea,Machineb,Machinec);
    int SetVars(int varoff, int n, int poff)
       persist.UserData[PC_COMM_PERSIST+2] = n;       // number of elements
       persist.UserData[PC_COMM_PERSIST+3] = poff;    // persist offset (doubles)
       return DoPCInt(PC_COMM_SET_VARS,varoff);       // Var index and Cmd
       return DoPCInt(PC_COMM_GET_VARS,varoff);       // Var index and Cmd
    #define GATH_OFF 0  // define the offset into the Gather buffer where strings are passed
    // Trigger a message box on the PC to be displayed
    // defines for MS Windows message box styles and Operator
    // response IDs are defined in the KMotionDef.h file
       char *p=(char *)gather_buffer+GATH_OFF*sizeof(int);
       int i;
       do // copy to gather buffer w offset 0
          *p++ = *s++;
       }while (s[-1]);
       persist.UserData[PC_COMM_PERSIST+2] = Flags;  // set options
       DoPCInt(PC_COMM_MSG,GATH_OFF);
       return persist.UserData[PC_COMM_PERSIST+3];
    // put the MDI string (Manual Data Input - GCode) in the
    // gather buffer and tell the App where it is
    int MDI(char *s)
       int i;
          *p++ = *s++;
       }while (s[-1]);
       // issue the command an wait till it is complete
       // (or an error - such as busy)
       return DoPCInt(PC_COMM_MDI,GATH_OFF);
    // Put a Float as a parameter and pass the command to the App
       int result;
       persist.UserData[PC_COMM_PERSIST+1] = *(int*)&f;
       return DoPC(cmd);
    // Put an integer as a parameter and pass the command to the App
       int result;
       persist.UserData[PC_COMM_PERSIST+1] = i;
       return DoPC(cmd);
    // Pass a command to the PC and wait for it to handshake
    // that it was received by either clearing the command
    // or changing it to a negative error code
    int DoPC(int cmd)
       int result;
       persist.UserData[PC_COMM_PERSIST]=cmd;
       do
          WaitNextTimeSlice();
       }while (result=persist.UserData[PC_COMM_PERSIST]>0);
       //printf("Result = %d\n",result);
       return result;
    Sometimes the program KmotionCNC 4.33cc itself is paused, she can completely shut down, the axis sometimes not go to the right place. This version is not stable.
    May 2006
    4047
    Hi Alexander,
    Very nice and thanks for sharing.
    There is a simpler and better way to check if a motion has completed using ChecDone(). Comparing floating point numbers exactly can sometime cause problems because of small round off errors. So you might replace:
    with
    while (!CheckDone(2)) ;
    and
    with
    while (!CheckDone(0) || !CheckDone(1)) ;
    and
    with
    and
    with
    I don't know why V4.33cc would be unstable. Can you provide any information about when it happens and under what conditions. We will be making a new Test Version 4.33d with all these patches. You might try that to see if it helps.
    Regards
    TK
    May 2006
    4047
    KMotion/KFlop Test Version 4.33d Available
    Several new commands and bug fixes.
    For details see:
    http://www.dynomotion.com/Software/K...%20Changes.pdf
    Download here:
    http://www.dynomotion.com/Software/KMotion433d.exe
    TK
    Mar 2008
    13
    Thanks Tom, I'll try.
    The program version 4,33сс itself shut down if you do what any team through MDI. Not every time, and sometimes. But often.\
    Here are my settings and C files.
    Can help find the problem?
    Regards, Alexander.
    Attached Files Attached Files
    Oct 2007
    35
    Hi Tom
    4.33d is not stable. It crashed 3 times in a row. Then I went back to 33c everything was fine again.
    The crashing was once after saving my offsets (G54) and returning to the main screen ->crash
    Three times after setting up my offsets, then manually change tool on main screen ->crash
    But because at one point my MPG behaved strange before the crash (one axis was not possible to jog the other was fine) I suspect the error in the Kflop software. MPG is hard wired to Kflop.
    Regards
    Leo
    May 2006
    4047
    Hi Leo and Alexander,
    You are correct that test version had a significant bug in KMotionCNC introduced when adding the Run Time Interpreter Log. Turns out MDI, Tool Changes, and such invoke the Interpreter that then tried to log invalid data.
    Please see the new Test Release V 4.33f described here to see if it resolves your issues:
    https://groups.yahoo.com/neo/groups/...messages/10180
    Regards
    TK
  1. Automatic tool measurement
    By gunda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2013, 02:33 PM
  2. Problems with automatic tool length measure.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-12-2011, 05:00 PM
  3. automatic tool length setter
    By Scottyb in forum Mori Seiki Mills
    Last Post: 01-25-2011, 05:15 PM
  4. makino automatic tool length presetter macro
    By PETE1968 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2010, 09:30 PM
  5. Tool Length Measurement - No Button On Panell
    By avongil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-12-2008, 09:19 PM
