So i have some files I have made in Solidworks that are 3D files that I saved an as STL file. I can get them imported into ArtCam, but when I try to run the 3D toolpath it does all of the processing of the toolpath but it doesn't complete it how the file should look. There are saw teeth like marks all over the sides that should be straight and others that aren't cut out fully. The bit I'm using is a 1/4" upspiral flat bottom bit for both passes as the machine I use, a Probotix Fireball Meteor, doesn't have a bit change and I only know how to get it to do 1 bit per program as I am still new and learning CNC'ing.
Any ideas on what I can do to get this to turn out right would be greatly appreciated.
Thanks in advance,
Dan
Solidworks Top View:
Attachment 243710
Solidworks Iso View:
Attachment 243712
ArtCam Iso view:
Attachment 243716
How the ArtCam file looks after the toolpath is done:
Attachment 243714
