586,463 active members*
3,424 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Surfacing aluminum with 2.2kw spindle. Best tool for the job?
Results 1 to 5 of 5
    Nov 2017
    591
    After some reasearch it seems an actual face mill is out of the question for an er20. What's the next best thing? I'm already getting great results with just a quarter inch endmill, but I wouldn't mind improving it with a wider cut and better use of the tool rather than dulling just the tip. I was gonna order a half inch stub end mill to have specifically for facing but I figured I would ask first. Are there better options? Larger than half inch cut? Smoother finish than and end mill would give? Maybe a flycutter of some sort? The 6k minimum rpm is obviously also a limiting factor with larger diameter. If I am limited to half inch max cut, would an insert tool make more sense? If it gave equal or better surface as an end mill, I imagine replacing inserts is more economical. Open to suggestions
    35538
    Re: Surfacing aluminum with 2.2kw spindle. Best tool for the job?
    Never used one, but look at an Amana RC-3400.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2011
    692
    If you end up going the 1/2" mill route, for best finish try to use an aluminum specific mill with radiused or chamfered corners.
    Shars does have a 5/8" indexable with 1/2" shaft with cheap inserts, but.. it looks cheap..
    5/8" Mini Indexable End Mills - Indexable Milling - Indexable Cutting - Products
    They also have a set of fly cutters with 1/2" shank:
    3 Piece Fly Cutter Set - Fly Cutters - Toolholding - Products
    Need to grind your own inserts for those though, and HSS may be a big limitation on speed.
    Shars also has a 3/4" face mill arbor in 1/2" shank. That should work with a variety of small face mills.
    If you do end up with a face mill, you can get away with not using all the inserts. Just take out every other one if it's an even number, or just try a single insert (basically a fly cutter.)
    Nov 2017
    591
    Thanks for the tips. I did end up getting a zrn coated 1/2 inch 3 flute endmill with .008 radius from maritool. Its giving excellent surface finish. I spent a lot of time getting my spindle tram perfect, like within a couple tenths swinging the indicator 4 inches from center. I can pretty much remove machining marks by polishing with mothers using a felt pad on a dremel and get a mirror finish no problem. I think I'll hold off on trying to use anything larger for now. I'm pretty happy with the results I'm getting.
    Muhammad_Haroon Guest
    How to check at how much speed my spindle is moving
    Sent from my SM-J710FN using Tapatalk
  1. Surfacing with a disc shaped tool
    By -DG- in forum Uncategorised CAM Discussion
    Last Post: 03-06-2012, 06:41 AM
  2. Best tool for surfacing??
    By TacPyro in forum Benchtop Machines
    Last Post: 07-10-2009, 07:53 PM
  3. Surfacing 6061 T651 aluminum
    By hmc710 in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2009, 09:34 PM
  4. Which tool bit type for surfacing aluminum with a fly cutter?
    By cnczoner in forum MetalWork Discussion
    Last Post: 01-03-2008, 08:54 PM
  5. Surfacing Aluminum
    By rcazwillis in forum MetalWork Discussion
    Last Post: 04-09-2005, 04:29 AM
