586,269 active members*
3,228 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Newbie, Chinese laser cutter head moving wrong way on x-axis
    Jul 2014
    Hello!
    My husband and I just purchased and set up a 40w CO2 China laser. I know, you get what you pay for, and most people say not to bother with the China lasers but we don't have much money and figured we would test the waters with this machine first.
    We've got it set up, but when we power it on, the laser head moves to the top, but then all the way to the right instead of left and does not stop when it reaches the limit, making a horrible noise.
    Any advice is appreciated while we wait to hear back from the eBay seller
    Thanks in advance!
    Nov 2013
    88
    Re: Newbie, Chinese laser cutter head moving wrong way on x-axis
    First identify the problem axis. (sounds like Y but could also be X)
    There should be a setting in the software to change the direction, if not and it uses stepper motors you could reverse the wiring on one of the phases to change directions (software is the best option, wiring should be a last resort method).
    What software is it using to control the machine?
    Sounds like theres only a home switch(s) and no end stop switches, which is ok, but you dont want it to crash into the end like its doing now.
    Jan 2015
    9
    Im the same boat as you.
    Did you find out what the problem was?
    Scott
  1. NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    By plast744 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2014, 02:57 PM
  2. whats wrong with my laser cutter? (no clean and smooth cuts)
    By Bardiaesm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2014, 01:58 AM
  3. Laser cutter/engraver not moving along the Y axis
    By Rick61 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-23-2014, 04:51 PM
  4. Mori Seiki SL-25 Z-axis moving wrong amount
    By drlx3 in forum Mori Seiki lathes
    Last Post: 03-21-2014, 03:08 PM
  5. Chinese laser: when I press the left button, head goes right...
    By Mchawkeye in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2012, 08:33 AM
