586,388 active members*
3,359 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > build thread g0704/flashcut cnc
Page 1 of 4 123
Results 1 to 20 of 70
    I've been looking to get a cnc for a while, looed at the tormach etc, ended up with a G0704 conversion.
    I have the G0704 mounted on the stand, ready for conversion. I looked and talked to a few different vendors about getting parts for the conversion, it wasn't always easy to get answers or lead times, i understand most are mom and pop etc so expectations are what they are. But it seemed like most were behind by a few months or more, and luckily i got a bonus at work so after reading about the flashcut and taling to them a bit, it seemed ok. They're definitely expensive, and i don't like the way the quote system works on the web, especially that you can quote for sets they won't actually sell to you, but enough people have said their part about that i guess. I went with the higher amperage $3,500 kit.
    Box arrived yesterday, opened it up. Usual buckwheatish packing pellets in a flimsy box, but not damage on the outside.
    Each item was wrapped in bubble wrap internally,
    The flashcut controller was in another box, wrapped in polythene or somesuch, i would have liked to see an ESD bag, since there was a lot of charge imbalance in the packing material, and better safe than sorry, they're not expensive.
    All the parts out
    Some details
    Stepper a bit scratched up
    Manual/Software on CD's, I think it is also available online, my pc doesn't have a CD so i'll be looking for that. The CD labels are stickers and they were bubbled and peeling off, cheaper low volume production type of affair. I'd rather see the stickers put on the case instead, CD's are already temperamental.
    stepper brackets
    discolouration was there from the opening.
    Finish is ok, they're a little rough.
    Off to find a CD drive and take a look over the manuals..
    cheers
    Re: build thread g0704/flashcut cnc
    Copied over the CD's from an old laptop, installed the software, the installer sat looking dumb (no progress bar update) for about 10 minutes before installing then all was good. It's a MFC /SDI syle win32 app, looks like visual C++ 2008, they're using the cypress usb drivers ( maybe an FX) ( same as the torchmate, from the look of the filenames of the torchmate seems to be the same vendor?)
    Poked around it a bit, it nice and simple, no fanciness just plan UI design, which i like. I tried the demo a few days ago and it'd crashed within 30 seconds of using it, but working so far. The art redraw/reaction time of the GUI is a little bit sluggish, but seems to work loading fles and clicking around.
    Now i have to actually install the hardware and connect it all up to see if it does stuff.
    Installed the kit this morning..
    mounted the sprockets on the motors, 1" away
    this is where they sit
    all three done
    removing the X axis wheel, the keyway is a little shorter than the slot i noticed
    kept all the parts together, putting them that fit in the plastic bags for each section
    nuts and bolts to mount the steppers onto the plates
    all mounter and marked, z cable goes in a different direction
    belts added, gates 150 and an optibelt zr 130
    snug fit
    removing the Y axis mount
    added the spacer and sprocket
    and mounted with spacers, belt added, not tightened the stepper yet
    putting the extra bits in bags
    black end stops, i'd leave these off itle ht end in case you need to tweak something inside they pop off but weaken each time, came out the bag like this.
    x axis
    [imghttps://lh4.googleusercontent.com/-4i4plaE9_cU/U9UtglABI4I/AAAAAAAAqgg/5towoJa58g0/w1315-h987-no/20140727_094008.jpg[/img]
    bits in bags again
    end stops, the manual doesn't mention removing the bolts from the machine first, only mistake i found so far.
    z axis
    remove this, store away
    what it looks like before
    z added, sprocket added.
    the Z is definitely the fiddly one, the spacers can drop in a nicely sized hole at the front that luckily goes all the way to the drip pan, my heart sank when i heard it fall inside. The bolts were not easy to get in for the last 4mm or so. Hard to do with a standard L allen, t-bar much better.
    added the tset screw
    all together
    added the box, 123 was xyz, interesting thing, no E-STOP, just the off toggle.
    installed the software.... Until now everything was pretty smooth, the manual made sense and was well laid out, i'd have liked to see a few tips and tricks and some more detail about pulling the table/leads screw forward but otherwise great.
    So the software, I had the demo on the machine from when i first looked at it, i'd opened it, clicked and around and it had crashed, so i left it alone. Tried out the "live" version on my other cnc's pc and it worked. So first thing, remove the demo software, did that.
    Reinstalled the "live" software from the CD, ok so far, run it. It says my machine config file is too new and can't be opened, pick another, ok cancel, nope cancel says i need a config file or i can't continue ! (how about or re-run the wizard?)
    Ok uninstalled it again, delete the registry keys i see, and the flash cut data software folder, all gone, install again. Nope same issue, take another look , its using a ProgramData folder too, uninstall leaves a lot of stuff behind. So i remove that, re-run it and the wizard pops up.
    I did try to download the newer version of the live software, put my name/email/serial and u/p but it seems you have to register somewhere first, and i didn't feel like screwing around with it, plus the demo version is the newer one, and thats the one that crashed for me. So figured i'd go with the one that shipped and figure out the rest when i'm not in the sun.
    so c:\ProgramData\FlashCutCNC..etc. deleted all that folder...
    Set the machine, type options and jogged it around a bit. Noticed no obvious E-STOP in the software either, i must be missing it, there is a pause by the looks of it for the GCODE, but E-STOP and pause aren't the same. Loaded the Flashcut cnc example gcode file, their logo, and ran it, machine moved around fine.
    The speed settings are "faster/slower" buttons (so far that i've found ) that's leaving a bit to be desired i think, i like the simplicity but that's really simple. Anyway everything moved around as it should..
    I made a video of it, moving around but its just the motors moving the table.
    DIdn't have time to pick up bits and stuff from LMS on friday, so that is where i'm stopping for now...
    cheers!
    I pulled the Z sprocket and bolts and added a couple of washers to the bolts, just couldn't get the screws all the way in and they were a little loose.
    redid the y sprocket it wasn't quite far enough on the lead screw.. much more similar to the picture in the manual now.
    Jan 2008
    1532
    $3500 and uses stock screws and bearings?
    yeah, i know,.. stock everything, flashcut guys said they dont want to sell conversion kits that require any hardware mods, for one.. 8A version of the controller, the 2.5A(i think) is $2500
    Are You looking for legitimate Apple iPhone wholesale supplier or any other mobile phone brand supplier like Samsung, Blackberry wholesalers To Europe, USA (New York, Miami, California e.t.c), UK (London etc.), Hong Kong, UAE (Dubai), who can supply you original mobile phones - Apple iPhone 5s wholesale,Apple iPhone 5 & 4S wholesale ,iPad mini, iPad 3, The New iPad 5 / iPad 4 wholesale, BlackBerry, Nokia, Samsung (Galaxy Note 2, S3,S4 ,S5 etc.), LG, HTC, Motorola, etc.
    Don't waste your time and money on fraud companies, Get your mobile phones & tablets at wholesales prices from us.
    We are Verified Wholesale Supplier of Mobile phones to Europe, USA, ASIA, Middle East
    We have been supplying various mobile phones & tablets for more than 2 years, We ship directly to the following countries :
    United States, France, United Kingdom, Germany,
    Denmark, United Arab Emirates, Italy,Russia
    Portugal, Hong Kong, Bulgaria, Singapore,
    Poland, Spain, Sweden, Israel, Pakistan,
    Canada, India, Czech Republic, Hungary,
    Romania,Slovakia, Austria, Netherlands E.T.C
    We Consider ourself responsible for every required charges needed to deliver your order to your doorstep.NO HIDDEN FEE OR EXTRA CHARGES
    We are legitimate wholesalers of mobile phones and tablets for your retail shop, internet shop, eBay shop, Craigslist or even a wholesale company. Start your business with trustiness of best legit wholesale suppliers To Europe, United States, Dubai, Hong Kong and other parts of the world.
    Skype ID : ozmobilephone.limited
    CONTACT US TODAY :
    [email protected]
    Oz Mobile Phones Ltd is a legitimate and verified wholesale supplier of mobile phones and tablets including Apple iPhone's, iPad's and other mobiles. We are registered company and we have been in this industry for 3 years. We deal only with original mobile phones and other electronics.
    Avoid scam and fraud sellers, purchase only from verified and legit supplier.
    Start your iPhone/ other mobile phones business now - buy phones straight from Oz Mobile Phones Ltd.
    We also sell to individual. You can buy 1 unit or more from us. We offer BUY 2 Unit and GET 1 FREE Unit With FREE SHIPPING.
    WE OFFER :
    Buy 2 units of Apple iPhone 5s 64GB --@ $400 Each = $800 USD and get 1 unit FREE
    Buy 4 units of Apple iPhone 5s 64GB --@ $380 Each = $1,520 USD and get 2 units FREE
    Buy 5 units of Apple iPhone 5s 64GB --@ $350 Each = $1,750 USD and get 3 units FREE
    Our Prices are :
    Apple iPad:
    Apple iPad 5 Air Wi-Fi + 4G 128GB ....$400 USD
    Apple iPad 5 Air Wi-Fi + 4G 64GB .... $380 USD
    Apple iPad 5 Air Wi-Fi + 4G 32GB .... $350 USD
    Apple iPad 5 Air Wi-Fi + 4G 16GB .... $300 USD
    Apple iPad 4 Wi-Fi + 4G 64GB--------------$300
    Apple iPad 4 Wi-Fi + 4G 32GB--------------$280
    Apple iPad 4 Wi-Fi + 4G 16GB--------------$250
    Apple iPad mini Wi-Fi 64Gb----------------$250
    Apple iPad mini Wi-Fi 32Gb----------------$240
    Apple iPad mini Wi-Fi 16Gb----------------$200
    Apple iPad 3 Wi-Fi + 4G 64GB--------------$250
    Apple iPad 3 Wi-Fi + 4G 32GB--------------$230
    Apple iPad 3 Wi-Fi + 4G 16GB--------------$210
    Apple iPad Air ----------$250
    Apple iPhone:
    Apple Iphone 5s 16GB ---$300
    Apple Iphone 5s 32GB ---$350
    Apple Iphone 5s 64GB --- $400
    Apple Iphone 5c 16GB ---$300
    Apple Iphone 5c 32GB ---$350
    Apple iPhone 5 64GB -----$300
    Apple iPhone 5 32GB -----$280
    Apple iPhone 5 16GB -----$250
    Apple iPhone 4S 64GB------$250
    Apple iPhone 4S 32GB------$240
    Apple iPhone 4S 16GB------$220
    Apple iMac:
    Apple iMac 21.5-inch: 3.06GHz --$690
    Apple iMac 21.5-inch: 3.2GHz ---$720
    Apple iMac 27-inch: 3.2GHz -----$900
    Apple iMac 27-inch: 2.8GHz -----$930
    Samsung:
    Samsung Galaxy S5 --$400
    Samsung I9505 Galaxy S4 ---$320
    Samsung I9500 Galaxy S4---$300
    Samsung I9506 Galaxy S4 ---$300
    Samsung I8200 Galaxy S III mini VE --$260
    Samsung Galaxy Express 2 --$290
    Samsung I9300 Galaxy S III ---250
    Samsung I9230 Galaxy Golden --$200
    Samsung Galaxy Note 3 ---$230
    Samsung Galaxy Core I8260 --$220
    SAMSUNG GALAXY NOTE 10.1 -- $230
    Nokia:
    Nokia Lumia 1020 --$250
    Nokia Lumia 520 ---$200
    Nokia Lumia 925 --- $200
    Nokia Lumia 928 --- $200
    Nokia Lumia 920 ---------$230
    nokia-lumia-820 ---------$220
    Nokia 808 PureView-----$210
    Nokia Lumia 720 ----$220
    Sony Xperia Z2 ----$300
    Sony Xperia M2 ----$300
    Sony Xperia Z2 Tablet Wi-Fi ----$300
    Sony Xperia Z1 ----$280
    Sony Xperia Z ----$250
    BlackBerry:
    BlackBerry Z10 Dev Alpha ------------- $380
    BlackBerry Q10 ---------------------- $350
    BlackBerry Porsche Design P-9981 ------$550
    BlackBerry 4G Playbook HSPA+-----------$330
    Canon EOS 5D Mark II --- $1000
    Sony Playstation 4 500GB - $400
    Microsoft Xbox One 500GB Console - $450
    Kindly Contact us for more product that are not listed above.
    Our On-Going PROMO Includes :
    Buy 2 units and get 1 unit FREE including shipping
    Buy 4 units and get 2 unit FREE including shipping
    Buy 5 units and get 3 unit FREE including shipping
    CONTACT US FOR A FASTER RESPONSE :
    [email protected]
    Mar 2004
    413
    $$$ Wise, one needs to understand that Flashcut does have a slightly different position in the market. A lot of the items they provide are specifically targeted at the non-hobbyiest where perhaps a small company has a machine they want to retro or get under control, but really can not afford to let one of their employees spend a few months accomplishing it. If we look at other G0704 conversion threads, they can span some months before you see that the project worked whereas frankly, YOU are posting videos of the machine moving in a WEEKEND. Now THAT IS worth SOMETHING !!!. So in this regard, the money is not the biggest part of the decision for a scenario like that, and you get really good control software to boot.
    At the hobby level however, I think most Flashcut users end up building their own cabinet with power supply and drivers of choice, but then use just the Flashcut software and signal generator because of the utter convenience and no nonsense operation. The Flashcut forum does clearly show that the program certainly has all the features people expect, it also shows that it is a product that really does work without the glitches or even the efforts sometimes required to find out why something doesn't work the way you would think it should. For many people, the cost of the software and SG is WELL worth the cost of that alone, and I believe that sells for something around the $1200 mark.
    Regards your start up quirks, I'd think that would be pretty typical for any new user..... Once you have used the product for a while, it ends up being a pretty routine event getting things up and running. It seems like your being patient enough to walk thru anything you have turned up. I love the program, and would not bother with anything else out there at this time. One thing that I really like is that I can run it with a laptop, and the laptop does not have to have ANY specific configurations. And, I don't have to wrestle anything else to make things work either.
    The cabinet you have there really does have some awesome motor drivers in it. I have one of those on a machine too that once had a very popular competitors drives running it. The difference was night and day between them. It's like a whole different machine. So, once all dialed in (and with any cnc control that you are allowed to "adjust", there is PLENTY to fiddle with), I think it would be an excellent machine with certainly only the machine hardware leaving some things to be desired as I tend to find with ALL imported iron (I've got an older Novakon... its not the quality of a 1940's piece of American history, but we all know that).
    Regards your E-stop issue. Well, first lets talk about why. It is my opinion that every machine needs a extremely accessible E-Stop. But, that can mean different things depending on what the machine is. The environment of a Sherline on a desk is obviously far different than that of a 6' x 10' Router or Plasma cutter. And, it really is the builder to make darn sure he has done EVERYTHING necessary to make it a safe environment whether that means a single mushroom head switch, multiple switches, perimeter cable switches, even human motion detection as in the case of robotic work zones.
    In your case, if you are mounting that cabinet within arms reach of that switch, it might not be so bad, after all, your not usually dealing with wicked fast rapid rates on a machine like that. Now it would be a lie to say that I've never seen a "runaway" with Flashcut because I have. I have used Flashcut on a dozen or so machines over the years, and there are all sorts of things that can introduce such "issues" (Interference from simple power surges to plasma and carbon arc torch activation). I find that 95% of my operational needs are solved with the Feed Hold. I have some machines where the hit ANY KEY "feed hold' feature is enough because a person happens to be standing right there by the keyboard on some machines, but yet on others, I have installed dry contact switching or wireless remote control of the feed hold on machines where there is the chance I am not standing there. All plenty easy to configure in Flashcuts I/O.
    Myself though, I fully agree with having a very real mushroom button and I too am confused why they have just have not gone with one in place of that rocker. A twist to release style would act like a similar switch and add the protection most of us are used to. I know if I made those cabinets.... they would have an E-Stop button.
    The key here though is that it does come down to the user making sure he covers all the bases, and in a lot of cases, that means building a safety interlock system PRIOR to their cabinet because it is essentially just a driver cabinet. When it is time for an E-Stop, Dropping power to that whole cabinet which includes the SG in this case is just fine. E-stop is to be the last ditch effort, not just with motion, but also spindle and whatever else can be a dangerous situation. I'd build an auxiliary cabinet to plug the Flashcut driver cabinet into, along with the main spindle power prior to any inverter. The switch can be placed in one or more convenient places. Some people will opt to locate that Blue Flashcut box right inside another NEMA cabinet with that electrical interlock. This way the driver cabinet is OE stock for any warranty issues.
    I would LOVE to have a G0704 with Flashcut on it !
    I think I need to put that on my Bucket List.
    Chris L
    Hey Chris,
    Thats pretty much exactly my reasoning, I read all the threads, spreadsheets watched lots of video and saw that a lot of people were talking a couple of years to do the conversion, I like building the machines, i can make my own drivers, write my own software ( i've done it before ) ,but this time I didn't really want to have another build a machine to build a machine project. I checked out other vendors and each one seems to sell partial kits, with potentially months of waiting lists, there are modifications that i had a hard time finding out exactly what was involved, they might be a lot simpler than I thought though.
    I installed the kit in a few hours, it took me longer since i was taking pictures as a i was going along. I lucked out in that I got some extra cash at work that was unexpected and that switched me to this kit, most of the other motor mount kits i've seen are about $800, so that plus control hardware and software, it's getting close, the flashcut is definitely on the expensive though, most people seem to give the software good reviews, and i do like most of the simplicity.
    Yeah the fact there is no e-stop is definitely strange, even my cheapo ebay special CNC 3020 has one. The feed hold has latency on it, it's as bad as 800ms on some operations since the software/laptop isn't really in control, the box is, also if you fumble and hit two keys it can start again, something an e-stop wouldn't allow. I noticed if you pressed certain keys ( a i think) it'd complain about the position changing, using it as a feed hold. I agree its upto me to ultimately make it safe, but there is no question it should have an e-stop, just seems common sense.
    Things like not including limit/home switches, it is only a few bucks of hardware, maybe most people don't use them ? They're certainly useful on my other cnc's. They're an additional cost, though its doubtful I can buy them from flashcut for close to what i can buy the parts for, plus don't know if i'd want to go with microswitches for a machine that generates that much mess. It's not much of an add to the raw cost of the kit, but when i opened the box I did have a an initial, huh is that all there is.
    Obviously they know their kit is higher priced, since they use that quote system. Even for kits they won't actually sell you. So far I'm happy, and I'm trying not to think too hard about the cost of it,and just focusing on the fact I've got it almost running in a short time, thats basically why i was ok paying it.
    cheers,
    charlie
    Made my first cut, smallest endmill i had in that size, did a quick test in redwood first.
    these are the settings i modifed, size of the cutting area i changed so the back of the vice didn't jam on the accordian covers.
    out of the box default setup the z-axis is inverted and the lead screw settings were half of what they should be for the XY and just under half on the Z.
    Attachment 244534
    Attachment 244536
    Attachment 244538
    I am winging it.
    Also i did notice the "e-stop" switch is an accessory add on....
    I've ordered 40A SSR's, the molex connectors for the back for the limit switches and relay control, also picked up one of those touch probes from ebay that are listed for linuxcnc
    I was looking around at the various droplet delivery systems vs misters, and i realised i had one of these in the garage. they're about $14
    Attachment 244540
    It is battery powered and has three nozzle settings for a continuous stream/drops/more drops settings. It also has a trigger lock so you can put it on lock, then add a little timer/relay to it to make it spray intermittently the lever is not analogue so the longer you press it the more comes out, so you can also just preset the trigger to where you want it then use a switch inline with the battery (or power supply)
    different settings.
    the delivery tube is in a harder outer shell tube, which can be removed so you just get a semi flexible tube to position.
    Today I added a Crafty CNC touch probe to the machine, i did try to find out about the flash cut cnc one they offered, but they don't reply to their own quoting system, tried a few times and gave up after a week and ordered one from ebay.
    CNC Touch Probe for Mach3 Linuxcnc 5 Foot Cable Length | eBay "CNC Touch Probe for Mach3, LinuxCNC - 5 foot cable length"
    ¼” shank (useable in CNC routers using ¼”collet) - [NOTE: if requested, I can provide turned down to 1/8"]
    Small overall size (body is 1” diameter, 1.25”tall)
    Comes with two interchangeable hardenened/ground stainless tips (.045” and .073” diameters provided)
    Uses standard M3-.5 metric thread, so you can use standard CMM style probe tips if you like (CMM styple probe not included in this sale, picture showing a ‘ruby tipped’ probe is for reference only)
    Adjustment screws so you can eliminate runout between shank and probe tip (this is important if you want to use the probe for accurate edge finding/centering of bores
    Detachable 5’ cord, makes it easier to set the probe up for adjusting runout (chuck probe in spindle and rotate against a dial indicator to dial it in)
    Probe activation force may be adjusted by replacing internal spring (3 springs: Heavy, medium, and Xtra-light NOW INCLUDED!)
    I'd probably choose the 1/8" option next time. For my Little Machine Shop startup kit, it fit a little tight
    Out of the box it is definitely a lot of force needed to trigger it, it'll work for anything but soft rubbers etc. It is nicely made and comes with a JST connector, personally i'd like to see the wire come out the side or the top and not the bottom though, i hooked it up to the line 8 and ground in flashcut
    parts, i got different sized pins for different cable AWG's
    ran a quick test
    left it runinng doing a probe of the first aluminium cut i ran
    Took me about 15 minutes today to add it into the controller, and set it up in the software to at least have it do an "uncalibrated" test.
    Hopefully this links to a video of it doing a rough test.
    https://plus.google.com/103597034352...34352682332839
    digikey parts list
    WM23707-ND CONN RECEPT 16POS DUAL
    WM9155CT-ND CONN TERM FEMALE 16AWG GOLD
    WM2503CT-ND CONN TERM FEMALE 22-28AWG TIN
    WM2501-ND CONN TERM FEMALE 18-24AWG TIN WM3704-ND CONN RECEPT 10POS DUAL
    Next i'm adding an SSR relay controller box.
    Jan 2013
    630
    I've got one of those probes. It works well. You could change the spring in it out for something softer if needed. The cable coming out of the bottom isn't really a problem. I loop the cable over something above the probe when it's in use anyway.
    Hi Kenny,
    Yep i've changed the spring to the medium and its running a test at the moment, the cable out the bottom hasn't been a problem, it's just a preference. I did notice its easy to knock the probe off the spheres it sits on, also just as easy to put it back. its a nicely made probe.
    I have a wierd thing where flashcut just stops for no apparent reason, i can continue the job but it'll just stop as if the feed hold has been pressed, i emailed the tech support guy, see if they have any ideas.
    Jan 2013
    630
    Quote Originally Posted by charliex View Post
    Hi Kenny,
    I keep mine in the holder I made that also covers the Z axis crank hole. Keeps it in a safe place and is easy to get to when I need it.
    nice, i wonder if he has a touch off tool as well, since the touch off is mostly an inverted touch probe.
    Jan 2013
    630
    After talking with the guys over a Calypso that do the Mach Standard Mill enhancement for Mach 3 I just made mine out of some half in aluminum plate and some single side copper clad fiberglass board. It stay mounted on the table. I use the probe as my master tool so everything gets measured against it via the touch plate.
    that is the style i have for my pcb cnc, i was looking at the sprung type, so it pushes the tool into it and measures it when the circuit breaks vs makes.
    though for my pcb mill the copper touch off has been fine, yours is nicely done though
Page 1 of 4 123
  1. My pre-build thread for my first milling machine! (G0704)
    By muibubbles in forum Benchtop Machines
    Last Post: 11-17-2012, 01:53 PM
  2. G0704 build
    By USN in forum Benchtop Machines
    Last Post: 09-10-2012, 05:53 PM
  3. Yet another g0704 build thread
    By kuyote in forum Benchtop Machines
    Last Post: 05-11-2012, 02:20 PM
  4. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  5. G0704 - CoB's Build
    By cobmachine in forum Benchtop Machines
    Last Post: 06-20-2011, 08:34 PM
