Hi everyone! I've bought couple of HEDS-9100 encoder modules and the passing codewheels. They seem to be perfect for my purposes, they are compact and also cheap!
I've read the following in the manual of the modules:
- Output Current per Channel, Iout .-1.0 mA to 5 mA
- Supply Voltage VCC Min: 4.5 Volts, Max: 5.5 Volts Note:Volts Ripple < 100 mVp-p
- Load Capacitance CL : 100 pF Note: 3.3 kW pull-up resistor
In your opinion, is this 5mA going to be enough for a Gecko for example? Or do I have to wire in a pull-up resistor on Ch.A and Ch.B? Is the 3.3 kOhms maybe the right value? :idea:
Furthermore, I've enclosed a picture with electrical characteristics of the modules, on which you can see a second pull-up resistor value: 11kOhms + a small capacitor. Whare does this resistor and cap go? Does anybody have maybe a schematic for wiring in such a module?
Thanks for the help: Giorgio
