586,416 active members*
3,172 visitors online*
Thread: KMB1-BX
    Nov 2013
    6
    KMB1-BX
    I am using A KMB1-BX. For G-Code I am using BobCam with the SolidWorks Plug in. It appears as if the BobCam Post is not putting the G-code in the right format for the hurco. In particular when it gets to a G3 with a large arc it fails. I reviewed the sample G-code from the Hurco USA website and noted that on the circle profile there was a bunch more code then when I run it through BobCam. Is anyone using a Cam software with the BX that works well? If so, what program. Any help will be greatly appreciated!
    Nov 2010
    59
    Re: KMB1-BX
    what post processor are you using ? Maybe martin cnc or accurate machine company may be able to advise on what post processor to use, I have converted my KMB1x to Mach3 so never tried to drip feed it G-code, I had read somewhere that although the kmb1x can run Gcode, it is on a limited basic level.
    Hurco Autobend servo Amplifier Board Repair, At Martin CNC
    Hurco Mill - Autobend, Parts Service Sales Repair INDEX
  1. KMB1 G18 help
    By mmachining in forum HURCO
    Last Post: 02-19-2008, 11:32 PM
  2. KMB1 dnc almost got it
    Last Post: 10-11-2007, 01:59 AM
  3. KMB1 bx
    Last Post: 09-14-2007, 03:28 AM
  4. Kmb1
    Last Post: 08-28-2007, 03:08 AM
  5. Kmb1 Help!!
    Last Post: 03-20-2007, 10:07 PM
