586,446 active members*
3,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Contaminated Coolant
Results 1 to 7 of 7
    Jun 2013
    Hello.....
    We bought a used okuma CNC machine...then filled up coolant tank...after 2-3 months, it became contaminated as shown in the picture... some of my coworkers says that it might be caused by bacteria and others say that it was the oil or the lubricant mixing in with the coolant.
    Please tell me whats wrong and how i can solve the problem.
    thanks..
    Attachment 243322[ATTACH=CONFIG]2Attachment 24332443322[/ATTACH]
    Jun 2004
    511
    Re: Contaminated Coolant
    What coolant did you use? Blazer is a good choice. A skimmer will pull the tramp oil out. The bacteria live between the tramp oil and coolant.
    Feb 2009
    6028
    Improper mixing of coolant -IE just putting in water without any concentrate
    Cheap coolant
    Not getting the tramp oil out.
    Jun 2013
    Thanks..for your reply... my company has 4 CNC Milling machines and all use same brand..'NOCOSOL' ... and only 1 machine has such a coolant problem...
    and that machine has little hydraulic oil leakage. it drop onto the coolant tank..so i fixed that.. is it possible oil with coolant make that contamination?.
    Mar 2009
    1982
    was the coolant system cleaned before filling up with new coolant?
    Jun 2004
    511
    Algirdas makes a good point. The leaking oil sitting on top of the coolant makes a place for bacteria to grow. If you have all the leaks fixxed and your coolant is OK in other machines, pull the tank and and steam clean it to remove any old contamination then you should be OK. A skimmer is cheap and works well.
    Jun 2013
    thanks for all the infos..you guys gave me. .. first of all.. i just filled up coolant without cleaning. it's my first cnc machine so i didn't know that and no one told me. this morning one man who supply all the coolant an Lubs to my company stop by and checked it...he said coolant and oil and bacteria all mixed.. and suggested me 1) drain all coolant 2) clean it with cleaner(he will give me, mix 2% with water and run over 24hour it will clean the tank) 3) fill up the tank with new brand coolant(Semi-Syn coolant) and new brand way-lube 4) install skimmer.. ... but it will takes a while to finish all the things.. and i will be off for next 2 weeks..so maybe i have to ask someone else to do this job for me....thanks again gentle men...
  1. Replies: 20
    Last Post: 02-23-2020, 10:09 PM
  2. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  3. Umm... What do you do with old coolant?
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2009, 10:12 PM
  4. Coolant Pan
    By BlueFin in forum Tormach Personal CNC Mill
    Last Post: 01-26-2009, 03:26 AM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
