HI!
I PROJECT TO BUILD A 48"X48" CNC PLASMA CUTTER 4 AXES THAT I CAN REPLACE TE TORCH BY A ROUTER MOTOR ON THE "Z" AXE.
MY QUESTION IS ABOUT THE "X" AXES, SHOULD I USE ONE MOTOR IN CENTER OR TWO MOTOR EACH SIDE ON THE "X" AXES FOR MOVING THE GENTRY TO MAKE SURE THAT ALL IS SOLID AND STABLE. IF I USE 2 MOTOR, HOW CAN I CONFIGURE IT TO RUN AT THE SAME TIME...
P.S. I WILL USE NEMA34 MOTOR
THANKS
