586,369 active members*
3,307 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Iges file with Bcc 26
    Aug 2007
    50
    Trying to do a quote. Was sent a Iges file. I started by saving it as a bobcad file. Reorganized, unstitched solid to surfaces, trying to select radius for dimensions can not get a wire frame to select on holes.
    Also google it for YouTube video their are none need some help here guys
    Sent from my SCH-R530U using Tapatalk
    Dec 2008
    4548
    Re: Iges file with Bcc 26
    utilities-extract edges-single....
    Better to leave the iges as a solid at first, then extract from solid and hide the solid. Then get the edges you need for dims out to separate layers. Then dim....
    Aug 2007
    50
    That worked great on the outside contour, but I found that if you cl see e up on hole theres three different lines. So its letting me delete many of the extra lines. Thanks this will work.
  1. iges file
    By hattonbiker in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2014, 05:04 PM
  2. iges file Les Paul top
    By Dconlee in forum Musical Instrument Design and Construction
    Last Post: 12-29-2007, 03:56 AM
  3. IGES file?
    By machining22 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-13-2007, 12:29 AM
  4. Analysing an iges file
    By Julian M in forum Mastercam
    Last Post: 12-09-2006, 10:16 PM
