586,655 active members*
3,295 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 spindle running in reverse
    Mar 2008
    29
    Hi all,
    I just converted my G0704 drive to timing belt and now the spindle run in reverse. To correct this, do I simply switch the motor wires on the motor controller or is there an easier way without having to re-solder the wires?
    Re: G0704 spindle running in reverse
    There should be no difference in spindle direction changing from the stock drive to a belt drive unless you did the little switch changing just the top gears to a little belt drive.
    In that case if you don't want to just swap the motor wires you can change them on the terminals of the fw/rev switch.
    Hoss
    Mar 2008
    29
    Thank you, Hoss. Yes, I did the little belt drive. I will take a look at the switch and see if I can figure it out.
  1. 770 spindle running in reverse
    By concombrefrais in forum Tormach Personal CNC Mill
    Last Post: 06-28-2013, 03:51 PM
  2. spindle won't reverse
    By gamila in forum Fadal
    Last Post: 08-04-2009, 11:32 AM
  3. no spindle reverse?
    By JoBwan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2008, 11:21 AM
  4. Can't reverse spindle
    By protrxrptr17 in forum G-Code Programing
    Last Post: 04-18-2008, 07:26 PM
  5. Spindle sticking in reverse
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2006, 04:48 PM
