586,132 active members*
2,578 visitors online*
IndustryArena Forum > CAM Software > CamWorks > UPG - how to do a simple equation in the post?
    Aug 2006
    259
    I'm just trying to get camworks to post out my dwell correctly. All I want to do is have the post pick up the spindle speed and divide that by 120.. I've tried everything that I can think of. I would think having this in the cycle would work
    Code:
     P<%:(120/OPR_SPEED)
    but it just returns 000..
    Any ideas?
    Just when you thought you had it all figured out, all hell breaks loose..
    Dec 2010
    126
    Re: UPG - how to do a simple equation in the post?
    I'm by no means an expert on this, but when I have to do something like this I format it as follows,
    P<#:ABS(120/OPR_Z_SPEED)>
    You have to make sure the entire equation is in parenthesis, and that the entire variable is within brackets < & >. You should be using the pound sign instead of the percent as well. Finally, you have to make sure that the variable is being output at a time when the spindle speed is not zero. I know that sounds dumb, but it can happen.
    Hope that helps.
    Mar 2008
    111
    So that should be, P<%OPR_SPEED/120)
    I'm sure your VAR would be more than willing to help you out
    :T:P<%: (OPR_SPEED/120)><EOL>
    Make sure you had put this after at least one tool section, or it will always be zero.
  1. Equation in SW 2010
    By Jerseycnc in forum Solidworks
    Last Post: 03-22-2011, 03:27 PM
  2. Equation Problem
    By Normsthename in forum Solidworks
    Last Post: 12-08-2010, 02:29 PM
  3. Macro and/or Equation help
    By Gregory1966 in forum Solidworks
    Last Post: 02-25-2010, 01:53 PM
  4. deriving quadratic equation
    By HuFlungDung in forum Uncategorised CAM Discussion
    Last Post: 02-05-2008, 06:12 PM
  5. Equation format in g-code
    By Jester966 in forum G-Code Programing
    Last Post: 07-09-2007, 02:39 PM
