586,452 active members*
2,895 visitors online*
IndustryArena Forum > CAM Software > UG NX > Problem with NX7.5 Lathe cam post
    Feb 2013
    Friends , I got a problem with my UG NX 7.5 Lathe CAM. the posted programs had the x values in radial method. but my CNC lathe with sinumeric 802 controller is with Diametrical type of programing. ie if we need a 10 mm dia to be turned, by using NX 7.5 Lathe cam the output program have the value of x as 5 mm. please get me a way out.
    Varun
    Aug 2008
    71
    Re: Problem with NX7.5 Lathe cam post
    If you can edit the post in Post Builder,set this in Machine Tool, General Parameters, Axis Multiplier, Diameter Programming .
    Mark Rief
    Siemens PLM
  1. bridgeport romi lathe Post problem Please HELP
    By MAnZ in forum Bridgeport / Romi Lathes
    Last Post: 01-25-2012, 03:41 AM
  2. Problem with Duality Lathe Tool Post Holder Alignment
    By anglin in forum Tormach Personal CNC Mill
    Last Post: 11-14-2011, 04:09 AM
  3. new lathe problem
    By tjd10684 in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2011, 04:21 PM
  4. Dolphin Partmaster Lathe Mach3 Post problem?
    By Jason3 in forum Dolphin CAD/CAM
    Last Post: 04-30-2009, 10:57 PM
