586,369 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Are there any big-travel CNC desktops available in UK/Europe?
Results 1 to 16 of 16
    Aug 2006
    1602
    Ideally I'm looking for something about the size and weight of a Tormach 1100 or better still Novakon Torus Pro, but the only off the shelf CNC's I've seen are the much smaller Seig KX1/KX3 and the SYIL X-series.
    I could just about cope with 18" of X and 10" of y-travel, but really 24x12" would be better.
    Cheers.
    Oct 2010
    1189
    Re: Are there any big-travel CNC desktops available in UK/Europe?
    Hi what do you want to cut .. do you need atc ? ...
    Aug 2006
    1602
    I want to cut steel and aluminium - I don't want anything routerish, I want a really meaty mill, preferably CNC out of the box, though I suppose a BF46 Vario + CNC Conversion might be an option.
    An ATC would be nice, but is not essential.
    Cheers.
    Oct 2010
    1189
    Hi i do have a klippfeld f12 which i converted to Cnc which has similar envelope like bf 46 but ,.. It is made in Austria ,.. I will Post the New spashguard i got ,..
    Jan 2007
    1332
    Quote Originally Posted by digits View Post
    Tormach 1100
    Aug 2006
    1602
    Quote Originally Posted by Don Clement View Post
    Tormach 1100
    I may well end up just importing one myself , but being at least 3,500 miles away from the nearest spare part makes me a bit nervous about spending the $11,400 I reckon it would cost me to import a base machine with no stand or accessories ($1000 shipping + 20% Tax in the UK).
    Given that all the machines start life in China, it seems likely that someone a bit closer to me is already importing/rebadging/supporting them...
    Jun 2006
    3063
    Tormach generally ships spare parts same day, though air express would certainly increase your cost quite a bit. They also have a spare part kit and that might be a good idea to buy along with the mill, especially if your income depends on a functional mill.
    Mike
    Aug 2006
    1602
    TBH I am very tempted by a Tormach - I already have a lot of TTS tooling, but the X-travel is a bit too short for my liking.
    Oct 2010
    1189
    Hi The Mill i use (build Since 40 years in austria no China stuff )
    Has an table 200 x 750 mm travel is 175 x 440 mm
    Z axis around 300 mm (i would have to go down and measure )
    The Tool holder are iso30 ..
    So if you search like i did for a non chinese machine this could be an Option ..
    Aug 2006
    1602
    Quote Originally Posted by Tkamsker View Post
    Thanks - I think that's just a bit smaller travels than the machine I currently have. I may go look at a 'real' Opti BF46 soon - they are not cheap though!
    Oct 2010
    1189
    Do you intend to get an bf46 and cnc it ? I checked the travel it is not that much difference ; )-
    Aug 2006
    1602
    Hmm, the Opti website and user manual disagree slightly - the manual says 520mm in X and 260mm in Y which is significantly larger than your machine IMO. I really would like 200+ mm travel in Y...
    Oct 2010
    1189
    Hi you are right my Bad
    Optimum Maschinen: BF 46 Vario
    But maybe you lose some mm while cnc Ing ...
    Aug 2006
    1602
    Yes, that's possible! I am going to go and see a BF46 at the end of this week - it will be interesting to see where they've added 200kg over the BF30!
    Oct 2010
    1189
    Hi
    you know that because of the sky fire disaster i now really look into "is it possible to have" non china mills ,..
    that is why i also have an eye on that optimum stuff
    The bf46 has is40 as far as i have seen this means the spindle should be massive that adds some kg ,..
    I hope you find your 200kg
    I had an look at cnc and optimum Optimum Machines: M 2LS / M 2LS ADVANCED
    and they have less travel ,..
    (i am glad that my mind did not trick me ) so be sure you don't loos too much at travel ,..
    i did some lifting at weekend with my machine i designed a new kind of splash guard and since weekend the machine is on the new "bed"
    will look like a little bridgeport 412
    thoma s
    Aug 2006
    1602
    I think that M2LS is probably based on the Opti BF20!
    You seem to have to go for very large machines to get much bigger travels once you go to a 'proper VMC' - but unlike most benchtops, they don't seem to have a 2:1 or greater X:Y travel ratio. E.g. this 'mini-mill' XYZ MINI MILL 560 - Vertical Machining Centres and Production Solutions - XYZ Machine Tools has 560x400mm X and Y travels.
    And if you have the room and 3-phase power, not hugely more expensive than the Opti B2LS if you by used : XYZ 560 Mini Mill
  1. Looking for kit in Europe
    By Busch_dk in forum DIY CNC Router Table Machines
    Last Post: 08-20-2013, 08:14 PM
  2. Morntech-europe + Laser tubes delivery to Europe (Belgium)
    By gillespinault in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2013, 05:04 PM
  3. Discuss Desktops and Laptops here!
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 06-13-2012, 05:50 PM
  4. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  5. archiving programs on floppies/desktops
    By chipsinpan in forum Milltronics
    Last Post: 01-06-2010, 04:57 AM
