587,003 active members*
2,966 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Waterjet vs Laser for 1.00"+ Carbon Steel
Results 1 to 4 of 4
    Jul 2014
    2
    Before you roll your eyes at ANOTHER jet vs laser thread, understand that I have done some homework on the subject. My understanding is that my needs fall in the "gray zone" between the two processes' strong points.
    Basically, I'm open to suggestions on both the debate between processes and specific models to cut 1-1.5" Carbon Steel plate as effectively and economically as possible.
    Apr 2012
    40
    Re: Waterjet vs Laser for 1.00"+ Carbon Steel
    We have waterjets and lasers, and for 1" thick materials I would go with waterjet out of the two choices, we cut titanium with the lasers and struggle to get them to efficiently cut anything over .250". I would think a plasma cutter would be a better option than Laser if you are looking for something to compare waterjets to.
    Jul 2014
    2
    Our company has a plasma table. It leaves poor edges, most likely due to improper calibrations by those using it. It is also at another location.
    What feed rate (rough estimate) would a waterjet be capable of operating at for this material type?
    Apr 2012
    40
    For what you want it would be around .500 - 1.00ipm depending on pressure available (ours are 90,000psi) and finish wanted.
  1. Replies: 2
    Last Post: 11-19-2013, 09:03 PM
  2. Laser/Plasma/Waterjet 1/4" Steel Plate Gussets
    By sanddrag in forum North America RFQ's
    Last Post: 01-08-2013, 07:27 PM
  3. Laser Cut / WaterJet Mild Steel Parts
    By GNS in forum Employment Opportunity
    Last Post: 10-02-2007, 11:00 PM
  4. RFQ 5/16" black delrin - laser or waterjet cut - fast turnaround...
    By InspirationTool in forum Employment Opportunity
    Last Post: 07-11-2007, 07:51 PM
  5. Cheapest and cleanest way to cut 1/4" G10? Waterjet? Laser?
    By Aaron92SE in forum Glass, Plastic and Stone
    Last Post: 02-28-2007, 04:34 AM
