Hi... i'm using EA8 EDM die sinker. on the E-Cond panel there are such ES, AUX, IP, ON, OFF, GAP, JS, JU, JD, PCOND, GAIN, SV, OPAJ, etc... what is this short form represent for? and what is the unit for every value..
they are your generator and power supply setting. If you have created a program with ESPER, it will populate those setting automatically. On pages 3-3 thru 3-7 of the auxiliary manual they give a detailed explanations of what each means. There are no set values because they change based on the burn you are doing at that time..again, ESPER asks you for the info then sets the machine. You can input/modify the settings but, if you don't know what they mean you probably should change them.
