586,271 active members*
3,198 visitors online*
    Jan 2006
    Cutting Issues..
    I have a Hugo Hurricane Laser 60w.. all the sudden I'm unable to get good cuts as the laser travels from back of machine to front. So confused on what would cause this the power meter appears to be showing enough power. Anyone know if this is a indication of bad laser tube.
    Jan 2008
    940
    Re: Cutting Issues..
    sounds like an alignment problem
    Quote Originally Posted by gresults View Post
    do you mean you can not cut the material through?
    or you can cut it through, but the cutting edge is bad?
    if your problem caused by alignment.
    here's a video may help you check and adjust the alignment:
    https://www.youtube.com/watch?v=pw8Ro2vEEzY
    www.thunderlaser.com
    Nov 2009
    314
    Hey there's many reasons...such like
    1.Water temperature getting hot,water circulate bad(block,leak)
    2.On mechanical aspect,working table no flat,laser head clamp bracket loose---cause mirror or lens not fasten inside/focus length change while cutting
    3.Optics alignment check one by one carefully
    4.Laser tube/power supply problem, aged or broken
    Best regards/Ms.Mary from XYZ Machinery
  1. having some cutting issues
    By hammertoe in forum Hypertherm Plasma
    Last Post: 02-20-2012, 09:39 PM
  2. 2.5D Cutting Issues
    By Smooth90 in forum Uncategorised CAM Discussion
    Last Post: 11-07-2011, 12:26 AM
  3. cutting issues
    By bolton78 in forum MetalWork Discussion
    Last Post: 02-03-2010, 03:09 AM
  4. 303SS V cutting issues
    By zcases in forum Material Machining Solutions
    Last Post: 11-07-2009, 10:59 PM
  5. Cutting issues Please HELP
    By SPEEDRE in forum Machines running Mach Software
    Last Post: 07-07-2008, 01:26 AM
