586,690 active members*
2,925 visitors online*
Results 1 to 7 of 7
    May 2008
    107
    Boot menu on Fanuc 20i
    Hi all.
    Please help me to go into boot menu on my Fanuc 20i system. I was follow up " Starting the Boot System" procedure as manual: I push and hold down two right most soft key when power on, but the system can not go to boot system, and go directly into normal boot and display so many alarm.
    Thanks you.
    Jan 2011
    350
    Re: Boot menu on Fanuc 20i
    Boot by holding down number 6 and number 7 from keypad and see what you get.
    May 2008
    107
    Hi botha.y
    Thanks you so much for your reply, but I do it already and get the same result. Do you know another way to go into boot menu?
    Nam.
    Jan 2011
    350
    In the CNC menu on screen after control is loaded up, does your keypad and menu keys function properly?
    May 2008
    107
    Dear botha.y
    Yes, the keypad work fine. I have same problem with 160i, 210i system, with is used NCboot software. Once powerred, if system display" NCboot start" then I can not goto boot menu.
    Jan 2011
    350
    Well you press the two buttons before, hold them, and only then you power on the machine. Since you say you couldn't get it done for 3 different machines with 3 different Fanuc i controls, must be that you were not doing that. If that really doesn't work, maybe some weird design, lower the main disconnect switch, get someone to press those two keys, raise the main disconnect, then power on. As far as I know the boot menu cannot even be blocked by the OEM.
    May 2008
    107
    I mean that I only have trooble with those controllers, and get good result with another ones( Oi, 16i, 218, ect...), and I don't know why I can not goto boot menu on those machine.
    But thanks you, any way.
  1. Hardinge Cobra 65 - Fanuc 21-T - Wont boot up?
    By keindustrial in forum Hardinge Lathes
    Last Post: 03-30-2024, 01:27 PM
  2. Fanuc 160i .Cannot boot
    By Jeff_B in forum Fanuc
    Last Post: 05-19-2013, 11:48 AM
  3. Fanuc 11M Check Instruction during boot
    By KLampkin in forum Fanuc
    Last Post: 05-09-2011, 01:55 PM
  4. 10tf boot / startup to IPL menu
    By Drew in forum Fanuc
    Last Post: 07-17-2009, 12:04 AM
  5. FANUC 0i-TC OS boot files required!!!!!!
    By biazbaba in forum Controller & Computer Solutions
    Last Post: 08-06-2008, 12:52 PM
