586,655 active members*
3,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori Seiki NV5000, How to open the side door to set up tool when machine is running
Results 1 to 10 of 10
    Apr 2011
    17
    When I run OKK 550 Vertical Mill, I can set up tools for the next job by calling old tools and changing new tools at its side door.
    But I can not open the side door and rotate tool change magazine in Mori Seiki NV5000. It takes along time for me when setting up new job.
    Can anyone show me how to do this?
    Thank you.
    Feb 2009
    6028
    Re: Mori Seiki NV5000, How to open the side door to set up tool when machine is runni
    Manual mode, door unlock button. All other doors have to be closed. Easier to load through the spindle.
    Apr 2011
    17
    I tried last night already and could not do it.
    Machine was running a program in TAPE Mode and whenever I tried to hit or activate other buttons, it stopped right after that.
    Is there any other way to try, sir ?
    Feb 2009
    6028
    It WILL NOT open while the machine is running, tape mode or otherwise.
    Apr 2011
    17
    Attachment 243160
    I hope you can read it.
    Thanks.
    Feb 2009
    6028
    Like I said, you can not open that door while the machine is running.
    Apr 2011
    17
    Actually, in some jobs, a cycle time is very short while setting up requires long time. I have to wait.
    Thank you.
    Jan 2007
    7
    Quote Originally Posted by underthetire View Post
    Odd, on the horizontals you can. It's just wont let you open during a tool change, I usually hit cycle stop while a cutters out of the parts and open'er up.
    You must hit the manual button, wait for it to light up. You can't rotate the mag when the door is open, so you would hit manual, wait for the light, get to the pot you need, open door.
    If you have a tool breakage detector, It might get picky. Don't do anything while the probe cycles.
    Feb 2009
    6028
    The horizontals have a waiting pot.
    Apr 2011
    17
    Oddly, They made that door for what while it is not used ???
    Does anyone think so?
  1. mori seiki door lock
    By guardianind in forum USA Club House
    Last Post: 02-28-2014, 02:46 AM
  2. Mori Seiki DuraVertical 5100 Door Interlock Bypass
    By Perfect Circle in forum Mori Seiki Mills
    Last Post: 01-24-2014, 11:50 PM
  3. Mori Seiki NV5000 battery drain
    By clamb in forum Mori Seiki Mills
    Last Post: 09-04-2013, 07:12 PM
  4. Need Help on Mori Seiki NV5000
    By dannifer.ebot in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2010, 07:45 PM
  5. Mori Seiki DTL open house
    By underthetire in forum Mori Seiki lathes
    Last Post: 11-20-2009, 07:11 PM
