586,898 active members*
2,801 visitors online*
Results 1 to 3 of 3
    Jul 2014
    3
    New Laser Cutter/ENgraver 150w - Engraving Advice
    Hi Guys,
    I have just purchased my first laser cutter 150w from China. (Reci laser Tube)
    So far it seem excellent and im startign to learn the basics for cutting/engraving. I have a question about engraving though.
    I have found that a good Power and Speed for some black anodised metal I have tested is about 'Speed 600 Power 25' . I have noticed though when going at about a power of 25% or higher when engraving the laser makes an occasional 'popping/arking' type noise for split seconds. Is this normal?
    It seems to engrave fine, and when im going at much higher powers when cutting things it all seems fine. I just wanted to find out if the popping noise is something normal when engraving at a higher percentage and certain speed? It does not seem to happen at a power of 20% for example.
    Any advice is much appreciated
    Thanks.
    Jul 2014
    147
    Re: New Laser Cutter/ENgraver 150w - Engraving Advice
    GN Laser is here. We are a professional laser cutting machine manufacturer in China. Maybe can help you solve the problem, but need you to send me more details about the model you bought. Such as parameters and some pictures.
    Email: [email protected]
    Skype: gnlasermarketing.3
    Tel: +86-15527861820
    Facebook: https://www.facebook.com/profile.php?id=100004590678876
    Nov 2009
    314
    Hey,there is sound-- laser hit on the material surface if power is somehow bigger when engraving. You'd better confirm where this noise come from.If you not sure,show it by you tube sure here many people in this forum can help and tell you.
    You sure it is not arc/shark inside tube if yes,check both positive and negative wiring connection after all power turned off, or this tube need to be change it is a quality problem.
    Regards,
    Ms.Mary
  1. Replies: 1
    Last Post: 08-03-2017, 08:08 AM
  2. Looking for advice on new laser engraver and cutter.
    By Moosewood in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-24-2014, 02:48 AM
  3. Replies: 0
    Last Post: 07-05-2013, 08:44 AM
  4. Engraving 40 W USB Laser engraver
    By pulguinha2012 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-15-2013, 04:24 PM
  5. 80w/100w/130w/150w/200w(GSI) laser cutter sp1290
    By SPC-laser in forum News Announcements
    Last Post: 01-26-2013, 02:57 AM
