I found this at QuickRout tool Sears. (I think its the one ger21 was talking about in another thread)
It says it fits a Craftsman router. It looks like it mounts to a 1/2" shaft on the router with a a 1/2" collet. The bit side has a taper shaped quick connect that the adapters snap into. The 1/4" router bits are held by the adapters with two set screws.
I don't know if it will fit a Porter Cable. Does anyone know what size shaft is on the Porter Cable router?
$29.99
Sears item #00926691000
Mfr. model #26691
http://www.sears.com/sr/javasr/produ...id=00926691000
Bill
