586,753 active members*
7,336 visitors online*
    Jul 2014
    5
    g01 gcode confusion????
    plz help me out ...i have a big confusion about g01 gcode.
    if i have this command
    G01X02Y02F100
    then what does it mean???
    i think it means that first tool move 2 inches or mm in x direction by the motor of x axis then tool will move 2 inches or mm in y direction through the motor of y axis and and reach at (2,2)???
    or it means that both motors (motor of x and y axis both) move simulatneously and the tool will move in diagonal line at an angle of 45degree and reach at (2,2) ???
    Feb 2007
    711
    Re: g01 gcode confusion????
    if the coordinates are on the same line, the axes will move simultaneously.
    Feb 2008
    586
    Quote Originally Posted by alan_3301 View Post
    And at a vector feedrate of 100. The angle created would depend upon the starting point, and whether the mode used is incremental or absolute (G91 or G90)
  1. Cam Confusion!
    By Mr Sprue in forum Uncategorised CAM Discussion
    Last Post: 02-22-2014, 06:24 AM
  2. G52 confusion
    By davek in forum G-Code Programing
    Last Post: 09-08-2007, 02:01 PM
  3. confusion
    By serry in forum DIY CNC Router Table Machines
    Last Post: 04-28-2007, 12:40 AM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. Multiplier confusion
    By Mike F in forum Servo Motors / Drives
    Last Post: 01-03-2005, 08:36 PM
