586,750 active members*
7,198 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V26 Problems,Layers,Selecting entities,and mask function
Results 1 to 2 of 2
    Apr 2010
    38
    Can any one help. I cannot find the layers anymore in the UCS windows ,how can i get it back?
    When I create entities from a solid and , then go to measure one of the entities as I am clicking on it it will not tell me anything about it such as the radius.
    When in mask how come after selecting to mask a specific item or items every time you go back into mask they are all back on?
    Mark
    Sep 2009
    105
    Re: V26 Problems,Layers,Selecting entities,and mask function
    Hopefully you've figured this out by now. If you accidentally closed the layer manager, right click on any toolbar and click "Layer-UCS-Post Manager" in the pop-up list. See the picture.
    I'm not sure why your entity measure is not working. Fix your layer manager and put your edges and surfaces on different layers, then hide the surfaces. This is the easiest way to ensure you actually click an edge instead of a surface.
    Masks are always unchecked after you cancel selection mode.
  1. mask on ark problem
    By forrey45 in forum Mastercam
    Last Post: 09-18-2011, 01:15 PM
  2. solder mask
    By mrendu43 in forum PCB milling
    Last Post: 03-01-2011, 12:08 AM
  3. Selecting entities
    By Stebedeff in forum Mastercam
    Last Post: 04-20-2009, 03:59 PM
  4. Mask On Arc Problem
    By Mastercam User in forum Mastercam
    Last Post: 05-22-2008, 02:32 AM
  5. Fanuc 11M M function problems
    By 9566317 in forum Fanuc
    Last Post: 03-17-2006, 03:30 AM
