586,576 active members*
3,717 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > MHP-30 Vertical Machining Center
    Mar 2008
    33
    We purchased a MHP-30 Vertical Machining Center a few years ago. I understand this machine was built by Hurco and I also understood when we purchased the machine that it was a black sheep machine if we ever encountered problems. The machine has ran exceptionally well since we purchased the machine and for the price we paid and what we have been able to accomplish with the machine I can not complain. However, we have encountered problems in the control and we received limited documentation when we purchased the machine. I have contacted Hurco and they are unable to provide a wiring drawings for this machine. Would anyone have wiring diagrams for this type of machine? If so, could we purchase copies of those diagrams to help us with repair on our machine? The machine has a Dynapath Delta 20 control. Any information available would be greatly appreciated.
    Thank you,
    Gary
    Jan 2011
    350
    Re: MHP-30 Vertical Machining Center
    From a quick look, here's some pdfs for the Dynapath control:
    Index of /pdf
    Aug 2005
    124
    I think what you have is a Moog Hydra-Point (MHP) machine, a great little machine, that has been retrofitted with a Dynapath control. AMT Machines in Seneca NY 716-656-2742 may be able to help. You may also try Visimetrics in the same region of NY state. The contact number is old so I wish you luck.
  1. BMC 20, Ultimax Vertical Machining center
    By Mahmoud_hola in forum HURCO
    Last Post: 03-17-2015, 11:56 PM
  2. Horizontal vs Vertical Machining Center
    By B.Reilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 08:09 PM
  3. CNC Machining Center- both Vertical and Horizontal - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:49 PM
  4. Beaver VC 15 Vertical Machining Center
    By MACHINEYARD in forum Uncategorised MetalWorking Machines
    Last Post: 11-11-2008, 08:40 AM
  5. CNC Vertical machining center
    By soumen in forum Mori Seiki lathes
    Last Post: 03-11-2008, 03:06 PM
