All,
I am finally getting around to setting up my Yamaguchi vertical CNC mill. It has 38mm or 40mm leveling screws, but did not come with any pads. My Mazak lathe came with steel pads that the previous owner made themselves because the leveling screws were jack hammering their way into the concrete. I always had the idea that it should be on rubber pads. What are your guys' thoughts on steel versus rubber? The mill is the same basic model as the one in the link below.
Yamaguchi Vertical Machining Center
Thanks,
Aaron
