586,637 active members*
2,931 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > My homemade brushless 3kw spindle
Results 1 to 20 of 23
    Mar 2014
    1131
    This is the first run.
    Please note this is not the final version but the very first. I've used regular ball bearings on this one but I'll change the design due to hot bearings. Got some angular contact bearings on the way for the next version.
    - ER20 chuck (shaft length: 100mm, shaft dia: 20mm)
    - 3kw 24v water cooled brushless motor (1050kv)
    - Cheap 200A ESC
    - Cheap servo tester
    - I'm using series wired two server PSU units.
    1695
    Re: My homemade brushless 3kw spindle
    Nice work. The bearings will run cooler if you replace the grease with oil.
    What RPM did you run it up to?
    Mar 2014
    1131
    25k rpm max.
    The housing is not sealed. Do I need to seal it when I use oil? Or just the seals of the bearings will do?
    Thanks.
    Sent from my GT-I9300 using Tapatalk 2
    Oct 2010
    1189
    This is a nice Setup question do you think it can be atc able ?
    Mar 2014
    1131
    Atc is another story. Maybe on the next version. For now all I care about is to getting rid of my noisy Bosch colt router.
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERS OF Precision Bearings use for CNC and Machine tool ,AND Radial-Axial bearings WHICH ARE MAKE OF Wafangdian Tianjiu Bearings Technology Co.,Ltd.
    WE ARE IN THIS BUSINESS SINCE LAST FIFTEEN YEARS; IN THIS SPAN OF TIME WE HAVE SUPPLIED PRECISION IN ALMOST ALL THE CONTINENTS OF THE WORLD.
    BESIDES, WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THE PRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    FEATURED BY HIGH PRECISION, LOW NOISE, HIGH ROTARY SPEED, HIGH QUALITY AND LONG SERVICE LIFE, OUR PRODUCTS SAVE USERS’ COST AND SHORTEN PURCHASE TERM. WIDELY APPLIED TO COMMON MACHINE TOOLS, CNC MACHINE TOOLS, LARGE / MIDDLE MOTORS, PRECISION ROLLING MILLS, ETC., OUR PRODUCTS FILLED THE DOMESTIC BLANKS AND CAN SUBSTITUTE IMPORTED PRODUCTS.
    THIS IS TO INFORM YOU THAT WE HAVE PRECISION BEARINGS AND OTHER GOOD QUALITY BEARINGS AVAILABLE, CAN SUPPLY FOR YOU WITH BEST QUALITY.
    WE HOPE CAN CORPORATION WITH YOUR COMPANY.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    THANK YOU !
    REGARDS!
    Lixingwen(栗星文)
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: http://www.wzfb.cn
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
    238
    Azalin, Does the ESC maintain constant torque?
    Mar 2014
    1131
    No, it does not gave a governor mode.
    Sep 2005
    1195
    Azalin,
    What motor you use on this spindle?
    Sep 2005
    1195
    Mar 2014
    1131
    Mar 2014
    1131
    Ok this is the first cut.
    15k RPM (max 24k)
    Feed 500
    Step down .5mm
    6061 aluminum
    2mm 2 flute end mill
    Jun 2009
    195
    Nice now I want to make one of them ! Very well done !!!
    Tony
    Oct 2010
    7
    Great build! How is the motor shaft coupled to the spindle? Which PSUs are you using?
    Mar 2014
    1131
    Thank you guys.
    @Calica
    The best way I've found to couple two shafts together is using a quality one way bearing.
    Mar 2014
    1131
    Second cut with 6mm end mill.
    Aug 2011
    21
    nice :cheers:
    Mar 2014
    1131
    Thanks BS
    Oct 2010
    1189
    very nice design question
    the er chuck did you buy that one or did you do it on an lathe or different machine ?
    Or question do you think it is possible to be done on an lathe ?
    Because i like your idea and i do think of building in winter also this kind of spindle
    and of course i would like to know which material you used on the "hull"
    thx
    thomas
    Mar 2014
    1131
    Hi Thomas. I made the hull from stainless steel. I don't know the exact code but it is soft enough to cut on a lathe. Not so hard and not so soft.
    Yes it is possible to make a collet holder on a lathe but once you are finished on the lathe you need to harden it without damaging or bending it. I bought mine from a local dealer. They are not expensive. Search on ebay for "er chuck holder". There are many types.
  1. DIY brushless spindle
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 09-27-2016, 01:37 AM
  2. Homemade lathe spindle
    By fredd3039 in forum Gunsmithing
    Last Post: 11-09-2014, 06:52 PM
  3. DIY Brushless Motor Spindle
    By cncEnthusiast04 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-06-2012, 12:49 AM
  4. spindle / headstock for homemade cnc
    By DrStein99 in forum Benchtop Machines
    Last Post: 05-03-2006, 04:46 PM
  5. brushless motor as spindle?
    By limbo in forum DIY CNC Router Table Machines
    Last Post: 03-02-2005, 08:01 AM
