Re: Larger balls in the C7 ballscrews
I have used a good amount of the RM-16 ball screws and non have ever had tight spots and .004" loose spots. Something else is the problem.
Test the screw without the seals installed. They are good screws and almost all will let you run positive preload without too much drag with the right sized balls. It is a real pain to get that last .001" of slop out unless you have every size ball.
It can cost more to buy 4 sets of balls than to buy double nuts that will be almost backlash free every time. In the end re packing ball comes down to the difference of 2 or 3 hundreds of a thousands.
youtube videos of the G0704 under the name arizonavideo99
